So i hit a snow bank not too long ago, and car is out of commission for a tad, so i wanted to find out the source of these problems and fix them before the car is operational, here is what i pulled;
Control Module Part Number: 8D0 907 551 A
Component and/or Version: 2.7l V6/5VT G 0003
Software Coding: 06611
Work Shop Code: WSC 06325
5 Faults Found:
17834 - EVAP Purge Valve (N80): Open Circuit
P1426 - 35-00 - -
I know this is self explanatory, any one know where exactly this Valve is, pics or diagrams would be helpful.
18014 - Rough Road/Engine Torque Signal from ABS: Electrical Malfunction
P1606 - 35-00 - -
Self explanatory, sending it to iPh0ne
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-00 - -
Now this is a Brand new MAF, just installed beginning of the summer, and after i reset the battery, later on it came on. Right now my rear o2 have been shut off some how and aren't reading, they are sitting in my engine bay attached. Any ideas?
17521 - Oxygen (Lambda) Sensor: B1 S1: Internal Resistance too High
P1113 - 35-10 - - - Intermittent
If im right, sound like the passenger side DP o2 sensor. Is it going bad or something else making it throw a CEL?
18011 - Internal Control Module Failed Self-Test
P1603 - 35-10 - - - Intermittent
Not a clue, can get a straight answer through search or online.
You help is all appreciated, im just trying to get this car back in shape again.
