I've had the car since july. And I am plenty capable of figuring this out myself. I haven't run into this type of problem before.
I would this on a forum like this I would think that people would be more willing to help troubleshoot rather than tell them to take it to a mechanic
When this happened, I excused it as being my turbos. Lots of smoke and no boost (and no noise). now I am looking deeper into it as I took it out the yesterday and it boosted fine.
The car is usually kept in a heated garage. when this happened it was parked outside all night, and this happened on startup, A month ago. My PVC system is obviously not STILL frozen.
I need to know what seals that this could blow. seals that would throw oil/coolant into the exhaust, and coolant into the oil.
That lead me to believe that seals inside the turbos where shot (oil and water both flow thru the turbos), or the Head gaskets (oil/water)
but I think you are right about it not being the head gaskets, What Would stop oil from going into the coolant, but allow coolant to go into the oil?
So now my guess is the turbos again. the oil is flowing and mixing with coolant, and leaking into the exhaust, while some how the coolant is being leaked out after mixing with the oil inside the turbo. causing the funny coolant code and underhood smoke. but they still spool!?
What is RMS?
