Results 1 to 4 of 4
    Jan 09 2009
    07 A6 4.2, 04 Volvo V70r, 03 BMW 540i Sport
    Connecticut
    Oil around Turbo Outlet
    I just did a oil change and noticed a small amount of oil around the turbo outlet attached to to the intercooler hose. It looks like it's coming out from the hose because their is no oil anywhwere else. Should I just replace the hose and get new clamps to se if this cures the problem?
    Your input is appreciated.
    Thanks.
    Veteran Member Three Rings Subaru71's Avatar
    Jan 15 2008
    2010 DGM Impreza WRX
    Chino Hills, CA
    Re: Oil around Turbo Outlet
    Quote Originally Posted by ctk1 View Post
    Thanks.
    There is always a small amount of oil inside those hoses and your entire intake system.. but if its leaking out, you should probably find out why.. how much oil are you talking about?
    2008 Phantom Black TQM
    Veteran Member Four Rings p1nk50ck's Avatar
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    yeah, i just swapped out my intake pipe back to the stock pipe on monday. i noticed a small amount of oil in the turbo inlet when i took the intake pipe off. not much, probably about a 1/4 teaspoon.
    the only reason why i wonder, is because i don't remember seeing it when i initially installed the intake.
    however, on monday, when i swapped back to stock, my car had sat untouched for at least 24 hours, and when i first installed the intake a month ago, i had driven about 20 miles to my friend's station. could that account for why i didn't see any oil during the install?
    any thoughts?
    Jan 09 2009
    Connecticut
    Please go to my photo gallery for the picture of what I'm talking about (not my actual pic).
    See where the bottom of the turbo outlet inside piece meets the outside wall of the turbo outlet...
    Where the two pieces of metal meet.
    It's leaking right there.
    What causes this?
    Can I reseal it?
    Replace a gasket?
    Any thoughts?
