Results 1 to 8 of 8
Thread: Stereo Question
    Veteran Member Three Rings teg2audi's Avatar
    Apr 23 2008
    Portland, OR
    Stereo Question
    I've searched and couldn't find an answer.
    My question is i've got the "Concert" series radio/cd player in my car which is ugly and peeling.
    I want to replace it with the Symphony II+. I've read a lot of posts about replacing the Symphony II with the II+ but never replacing the Concert series. Can this be done and is there a write up somewhere or a list of parts i will need.
    Black 04 Audi A4 1.8t
    APR Stage 2+, Koni FSD/Eibach, OEM USP Wheels
    Member # 15 of Coalition of The OEM+ Audi Owners.
    Veteran Member Four Rings forevraudi's Avatar
    Sep 01 2008
    San Diego, CA
    Re: Stereo Question
    i think it should be plug and play in the back, since its all OEM... i think you'll need a new harness that will accept the at least double din stereo and movement of the AC controls
    Apr 23 2008
    Portland, OR
    Re: Stereo Question
    Quote Originally Posted by forevraudi View Post
    So even though i'm going from the Concert to Symphony II+ just buy the Symphony II to Symphony II+ adapter without BOSE and that should work for the Concert model?
    Is this the adapter i should buy ?
    https://www.euro-parts.us/product.ph...263&bestseller
    How difficult is it to move the AC Controls i'm guessing it wouldn't be to much of a hassle to slide them down a few inches.
    Dec 06 2007
    Re: Stereo Question
    i think ur car is a single din right? if it is u need to move ur climate control system down and make space for it to fit.
    -Kirk
    BetaAlphaTau Member #58
    Jun 08 2008
    Calgary AB Canada
    Re: Stereo Question
    ^ as stated above, youll need to but a new climate control unit for double din stereos. check ebay
    Apr 23 2008
    Portland, OR
    Re: Stereo Question
    Quote Originally Posted by onceover View Post
    damn really? i didn't realize you would need a different climate control unit thought you could just move the old one down. Are you sure about that?
    Jun 08 2008
    Calgary AB Canada
    Re: Stereo Question
    99% sure, yes
    Dec 03 2008
    Orlando, FL
    Re: Stereo Question
    You're right. There are lots of info on Symphony's, but none on Concerts. I'm ok with the Concert if I can connect the Ipod adapter from ECS to it. Does anyone know if it will plug n play w/ a Concert?
