Today i finaly had some time to go to home depot to get parts so i can make a pressure test tool. I was hearing hising at idle but didnt think much of it. (It's leaking air not gas) I hooked up the tested and it dodnt even pump 1psi and i could hear hissing right away. Sprayed some brake cleaner and found 2 injectors leaking and one really bad.
I dont have AIR/FUEL gauge or VAG-COM so i couldnt see if im running rich. My o2 sensors cel keeps comming on and my gas get's low very fast. I assume the o2 cel wil go away when i get this fixed because o2 sensors were just fine when the motor came out.
What problems was i running into while i was driving like this? I drove the car about 500 miles total with this leak and me not knowing about it and many of those miles were WOT. Car pulls good but for some reason i think it should do better.
Here is some of my mods just in case you need to know
PJKO4's
630cc injectors
85mm MAF housing with hitachi maf
Gutted pre cats with 3" custom exhaust no mufflers
