Originally Posted by
serumk
I've heard the OEM front rotors are expensive... My car has 48k on it as well, and my rotors look good. I think one has a slight groove in it, but the pedal isn't pulsating, and the pads have LOTS of material left.
OEM B6 front rotors run about $75 each; rears about $10 each less. OEM-quality pads run about $150 for fronts and rears. Upgraded pads (Bobcats) run about $250 for fronts and rears. So for parts you're looking at $450-550. For labor, an experienced tech can probably do front and rear pads and rotors in 3 hours or so.
It is true that resurfacing rotors used to be done frequently, but I think most modern rotors are thinner so that they will be below spec if resurfaced. You may be able to get away with just changing pads. My feeling is that rotors are easy to do while you're in there, so just do the job once and be done with it. In addition, what will you pay to resurface a part that is a $75 replacement cost?
A royal shafting by the dealership, however, is priceless. . .
Sounds like you're experiencing classis dealer "scare the ignorant customer" tactics. On the B6, the rear pads wear much faster than the fronts. At 48 K, my rears had about 10-20% pas left while the fronts had almost 50% left. Call their bluff...brakes don't just "fail" suddenly due to wear-- they'll give you plenty of time (and miles) of warning. And find a good independent shop if you don't want (or can't) do the work yourself.
