Results 1 to 8 of 8
    Senior Member Two Rings M_souren's Avatar
    May 03 2007
    2001 Audi a4 TQM
    Bridgewater, North Jerz
    A lot of confusion
    Im somewhat confused. In order to have a slight bump in power, does one replace the cat's with a test tipe and then a downpipe, or can one leave the cat's on and just do a downpipe for the same amount of power?
    Sorry if this is asked alot, i searched and looked in the FAQ but couldnt find the answer.
    Audi's and Vw's galore
    Dec 05 2007
    Re: A lot of confusion
    The stock cat is rather restrictive. It will release a couple ponies when installing a HFC or Test Pipe. But right after that can be the restictive downpipe due to it's diamater. A better route is to due a complete exhaust at once (Test pipe/HFC and Cat Back Exhaust 2.5"-3").
    Senior Member Three Rings lifwanian's Avatar
    Oct 17 2008
    Dirty whores.
    NV
    Straight blackness on blackness. A 99.5 1.8tqm with a MTM Stage 1+, APR TBE with a custom race pipe, 18x8.5" BBS RC's, and a bunch of other little shit.
    Totaled - 12/11/09
    1/15/10 - 02 WRX - Half the luxury/comfort, twice the fun.
    May 03 2007
    2001 Audi a4 TQM
    Thanks lifwanian, for not reading the part that says the answer isn't in there.
    I dont want to do a complete exhaust, i want to keep the factory. Will just the downpipe show any gains or would it only be worth it if i only did the test pipe as well?
    Dec 05 2007
    Here the issue to add onto what I just posted. There is restriction of the cat converter, then there is the restriction of the downpipe. What was not post in the last post is you will still run into one more restriction, which is the exhaust piping and mufflers. I would suggest to do the entire thing, or else just keep the money for something else.
    May 03 2007
    2001 Audi a4 TQM
    i can have a friend make the downpipe for free.
    Dec 05 2007
    If it's free, then by all means go for it . Then when you have extra dough, get a HFC or Test Pipe. Then do the exhaust to be able to actually release those ponies.
    May 03 2007
    2001 Audi a4 TQM
    the plan was to make it one piece. 2.75 inches in diameter, maybe 2.5
