Results 1 to 8 of 8
    Jul 11 2007
    Lakewood Cali
    80K-ish Maintenance 04 A4
    Ok Guys. soooooo. i was wondering what more or less hsould be done as far as maintenance goes. so far what i have done is the major things i hope which are timing belt and water pump. what i have left to do is pretty much
    -valve cover gasket(leaking)
    -Injector "O" Rings
    -oil of course
    -cabin filter
    -coils
    -spark plugs
    -axles pretty soon theyre tickin and poppin all over the place haha
    anything else you guys can think of that should be done?
    thanks in advance
    5 Speed Manual just in case
    Sep 13 2008
    Western Chicago Burbs
    Re: 80K-ish Maintenance 04 A4
    fuel filter, power steering flush, coolant flush. tranny oil.
    all of this isn't necessary but if you're anal about maintenance like me, then do it
    Jul 11 2007
    Lakewood Cali
    Quote Originally Posted by B6JoeA4 View Post
    when i did my timing belt i did all of this. damn i forgot all about it haha
    thanks!
    Veteran Member Four Rings yung turbo's Avatar
    Feb 19 2008
    2005 A4 1.8TQtip-2011 A4 2.0tQAuto
    NYC/DE
    since you got your answer ill thread jack how much would 45k service be?
    TuRboK1ng
    You Are All Witnesses
    And The Yankees WIIIIIIIIIIIIIIIIIIIIIIIIIIN
    The Yankeeeeeeeeeeeees WIIIIIN!!!!!!!!
    Jul 11 2007
    Lakewood Cali
    so im pretty much all good if i do all this...no one recomends anything else?
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    Lube the doors and sunroof frame. O-rings on the injectors are not really necessary. Also your "axle" problems do not warrant replacement unless the CV joints are doing really poorly, plus they are expensive to replace. I would also run seafoam though the intake before and oil before you change it, and maybe one bottle through the tank.
    Clearly you are in the TB change zone as well. I'd push that to 90k max... but that's just an opinion. I changed my TB at 84,000.
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Established Member Two Rings audimcnasty's Avatar
    Jul 20 2008
    black B6, white Q5
    chicago
    Quote Originally Posted by yung turbo View Post
    45k for an 05 is just oil & oil filter....so about $50.
    http://www.bentleypublishers.com/ima....2005.main.pdf
    - eddiemcnasty
    Feb 19 2008
    NYC/DE
    Quote Originally Posted by audimcnasty View Post
    thank you much.
    TuRboK1ng
