Results 1 to 7 of 7
    Oct 07 2008
    Michigan
    Lower boost with TP and Exhaust
    I have the APR 93 octane chip, Test pipe and AWE exhaust. before i did ANY exhaust mods, my Podi boost guage was reading spikes af a little over 20 psi and riiiight after i did the test pipe and exhaust my boost spikes at about 18 psi now, maybe a little less depending on conditions. I have a forge DV valve that i maintain and my PCV is fine. Is this small los in boost due to less back preasure? any ideas? or is this normal and am i just retarded? haha thank youuu!!
    Established Member Two Rings grmntoy's Avatar
    Aug 11 2008
    -NYC-
    Re: Lower boost with TP and Exhaust
    mine is doing the same and i just have a revo chip and intake....i think it has to do with weather and timing.its cold here in NY
    Veteran Member Three Rings Subaru71's Avatar
    Jan 15 2008
    2010 DGM Impreza WRX
    Chino Hills, CA
    Quote Originally Posted by 08audi View Post
    did you just have this installed?
    It may be because your car is not used to the new airflow yet.
    When I first installed my FMIC, It went from spiking 22 and holding 18 to spiking 18 and holding 16 or so... then after a few weeks it went back to normal..
    2008 Phantom Black TQM
    Veteran Member Four Rings adub's Avatar
    Nov 20 2008
    spiders
    Orange County
    I hear this is very common. Not sure why but I have read this in an Article done by Canyon Racer Motorsports in Mission Viejo, Ca.
    -Andrew
    Senior Member Two Rings D-techniK's Avatar
    Feb 24 2008
    Miami Lakes, FL
    Doesn't hurt to try a throttle body alignment.
    Throttle Body Alignment:
    put the key and put it into the position just before the starter turns (do not start the car) push the gas peddle all the way wait 3 seconds and turn the key all the way back but do not take it out, now release the gas peddle and wait 2 minutes! remove key than put it back in and start the car!
    Established Member Two Rings Entropy333's Avatar
    May 12 2008
    Anchorage, AK
    Hmm...that's worth a shot. My car has APR 93 and I have never seen over a 16 psig boost..definitely not 18.
    ~James
    DUH! an Audi
    los angeles, CA
    did you get flashed for the tp? I dont recall reading you did...might be a cause of it, need to flash for the added airflow and what not.
    car does take a bit to adapt, give it a couple of days.
    -randy
