Results 1 to 28 of 28
    Senior Member Two Rings Alphazuzu's Avatar
    Oct 05 2008
    Holly Springs, North Carolina
    Snow finally=strange breaking problem. HELP
    So we finally got snow here in NC and i was excited to go to work. BUTTTT when i pulled out of the neighborhood I decided to do a preliminary test on the breaks and they made a horrible grinding noise and were pretty ineffective, practically kicked my foot off the pedal. I had a suspicion this would happen; a few weeks ago I lost traction around a turn and hit the breaks and the same thing happened I didnt think much of it then. I turned ESP on and off and had the same effect.
    If you have had this problem or know what it is please help me diagnose it.
    Thanks
    Veteran Member Four Rings A4A4A4's Avatar
    Jun 02 2008
    Victoria, Canada
    Re: Snow finally=strange breaking problem. HELP
    Quote Originally Posted by Alphazuzu View Post
    Thanks
    It's called ABS
    -Cam
    New: MK6 Volkswagen GTI
    Old: E92 BMW 335i
    Older: B7 Audi A4 2.0T Quattro
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    anti lock brakes... snow driving
    never hit hte brakes if you start sliding.. you can power oversteer our cars in snow. it's really easy and fun to do.. just makes sure ESP is off..
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Aug 14 2008
    '90 Cq - '13 R
    obamaland
    Quote Originally Posted by Jung View Post
    Yeah definitely keep on the power, it may take a while to get used to though.
    Established Member Two Rings ABsKiLLz's Avatar
    Jul 03 2008
    2002 Audi A4 1.8T
    Bronx, Ny
    Yeah, this happened to me a week ago causing me to get into a minor accident. I was approaching a red light and hit the brakes and then it wouldnt stop so i crossed the intersection and hit a car going about 10-15mph. Luckily everything was good, I came away with a scratched up front bumper and broken fog light grills. So then in snow driving its best to keep ESP off because of this? Off would be with the ESP light on or is it the other way around Off = ESP light off? I would really like help because i dont want to get into other minor or major accidents. THanks
    Veteran Member Four Rings maclem8223's Avatar
    Oct 16 2006
    04' A4 USP 1.8T QM
    RSM, California
    With ESP off the light will be ON
    ~Matt~
    BetaAlphaTauMemeber #45
    USPMemeber #1001
    04' 1.8T Q6M 2871R Revo Tuned
    Veteran Member Four Rings NightRoller USP's Avatar
    Aug 23 2008
    2008 Rs4
    Haha.....I forget that people arent used to snow driving!
    Jacob
    AWE ll APIKOL ll PODI
    USPCLUBMEMBER#190
    Aug 23 2008
    2008 Rs4
    Quote Originally Posted by ABsKiLLz View Post
    Engine breaking and slow breaking are key.......and slow down!
    Jacob
    USPCLUBMEMBER#190
    Oct 05 2008
    Yes fun but not safe for normal driving. I just want my brakes to work in the snow or even rain. It sounds like the general consensus is the ABS does more harm than good in the snow. My 98 Kia could go all day in the snow and have no problems with braking.
    So I guess atleast I dont have to take it to the shop.
    Veteran Member Four Rings Tgr_Clw's Avatar
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    No the general consensus is to use proper tires for snowy conditions.
    Appearance: OEM+
    Interior: B6 S4 Recaro Seats
    Performance: MTM Stage 3 / Milltek Exhaust+Milltek HFC / JJ TIP / ASP FMIC / SB FE SS
    Suspension: Vogtland Coilovers / HSport S4 Sways
    Braking: Stoptech 332 BBK
    Wheels/Tires: BBS CH 18x8.5, ET35 / GY Eagle F1 GSD3 235/40/18
    Jan 16 2007
    Wetzlar
    ABS means- you can use brakes to maximum and able to steer at the same time.
    Use proper tires according to season.
    Unskilled drivers should keep all driving aids on and attend real driving school.
    if car starts to slip - gently lift foot of gas and car will gain back traction. I see many recommend powering out of slides, this is not very good advice when there are other cars around, curbs, etc.
    Veteran Member Four Rings yung turbo's Avatar
    Feb 19 2008
    2005 A4 1.8TQtip-2011 A4 2.0tQAuto
    NYC/DE
    in stead of stomping on the brakes, use the tiptronic to downshift into first to slow the car down then brake
    TuRboK1ng
    You Are All Witnesses
    And The Yankees WIIIIIIIIIIIIIIIIIIIIIIIIIIN
    The Yankeeeeeeeeeeeees WIIIIIN!!!!!!!!
    Veteran Member Four Rings oildrpr's Avatar
    Apr 07 2007
    Huntington Beach, Cali
    fuk, can't anybody spell BRAKES anymore... Braking! Brake! Brakes! fukkin A
    Jun 02 2008
    Victoria, Canada
    No, you missed the point completely. ABS is a good thing, they prevent your brakes from locking and you from sliding. It gives you the ability to steer the car while you are breaking rather then just going right into the car in front of you. If you want your brakes to work well in the snow you have to equip the car correctly (i.e. snow tires or all seasons at the very least) and you also have to understand what winter driving requires and realize that the most important step you can take to driving safe in wintery conditions is to slow down substantially.
    -Cam
    Old: E92 BMW 335i
    Registered Member Two Rings
    Jun 08 2008
    Baltimore, MD
    This is pretty ironic after this post
    http://www.audizine.com/forum/showthread.php?t=258860
    Jun 30 2007
    Raleigh, NC
    Quote Originally Posted by Tgr_Clw View Post
    we don't get enough here to justify the money on anything more than your basic all season tire. chains are more cost effective around here than snow tires unfortunately.... but knowing how to drive - and when NOT to is generally the best thing for us southerners
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Sep 13 2008
    Western Chicago Burbs
    its Braking not Breaking
    Jul 07 2007
    Tempe, AZ
    i drove in wisconsin for a month in summer tires and had no issues. I know how to snow drive. just learn how to drive in snow... take the car to an empty parking lot or to streets with no cars and learn how the car will react to snowy conditions. most importantly SLOW THE HELL DOWN! *brake* (note spelling also), early.
    Jan 13 2008
    2008 A4 2.0t Avant 6spd
    Boston MA
    Quote Originally Posted by B6JoeA4 View Post
    Doesn't matter, its broken.
    2008 A4 2.0T Avant 6spd. Black on Black Ti S-Line
    Dec 09 2008
    Wisconsin
    Holy misinformation, Batman. ABS and traction control are put on cars for a reason, and that reason isn't to put people into accidents.
    If you're going to screw around and turn off ESP, make sure you're in a parking lot and nobody's around. Most of all, don't suggest advanced driving 'techniques' to people who are still trying to figure out what ABS feels like.
    For those new to ABS, it's meant to keep your car straight/under control when your wheels would otherwise lock up. This is a good thing. If you're sliding through an intersection and into traffic, it's because you're going too fast, not because ABS prevented you from stopping.
    Spiff, wondering what the hell driver's ed is actually teaching these days
    Jul 07 2007
    Tempe, AZ
    turning off ESP isn't even that big of a deal.. it teaches you how to drive better with it off. to the people who seem tentative/afraid to turn it off, you have QUATTRO! on dry ground, it doesnt do shit for me on/ off unless im launching. You don't have enough power to spin the tires from a roll unless you're BAMFT (bigassmofoturbo) or frontrash. Stop being vags and learn how to drive
    Jun 30 2007
    Raleigh, NC
    Quote Originally Posted by SpacemanSpiff View Post
    well i'll go ahead and let everyone here who keeps saying that he "doesn't know what ABS feels like" etc. know that the guy is a friend of mine and he's not a moron.... just because he isn't used to ABS in snow or particularly familiar with it doesn't mean he's incapable of controlling his car in other situations (like powering out of a slide or modulating the throttle etc). so throw your ASSumptions out the window.
    it feels different in snow... which *again* we do NOT get a lot of here. we got a miracle "blizzard" down here.. more than 5 inches of snow in a single day is some kind of record for this decade, the last time we had this much was back in the late 90's or early 2000's when we got 2 feet... so it's been a minute. (and since before either of us would have been driving. i think i was 14 or 15 the last time i drove in snow in cary... and that was MAYBE 3/4 of an inch)
    The Awesome™
    Jun 30 2007
    Raleigh, NC
    I'm only BAT and mine break loose in 1st gear without launching.... 2nd gear if i'm turning. (i can shift early to 2nd in an intersection, lag, and then the car will still slide when i hit boost)
    ESP is the devil's tool anyways. that crap never did anything but fuck me up.... i don't like a computer trying to do a job that my brain prefers to control.
    The Awesome™
    Veteran Member Four Rings JMRQuattro's Avatar
    Jul 04 2008
    Seattle, Washington
    ^^ has he never slammed on his brakes before until now or something? Cause i'm pretty sure ABS is not anything new. I understand he's not used to it, but holy crap.
    I'm sorry but it would have been really funny if the first reply would have said something like "OMG that's really bad! That's a sign that your brake calipers are failing and could fall off!" haha that would have been great.
    - Justin -
    Jul 04 2008
    Seattle, Washington
    Quote Originally Posted by B6Lovin View Post
    I agree. ESP is the antichrist. That crap just makes the situation worse most of the time. I think the only times it helps are those stories where people are driving on the freeway or somewhere with a high speed limit.
    - Justin -
    Jun 30 2007
    Raleigh, NC
    Quote Originally Posted by SeatownB6 View Post
    well have you ever slammed on your brakes on a normal, dry road -- and then gone out in ice and done it?
    it feels different.... on dry pavement you get the pulsation in your pedal but you don't get the audible "grinding" noise and the weird pedal feel/vibration... its completely different in bad weather and you should know that...
    that would have been funny though lol. (about the first reply)
    (btw, jared - if you see this and want to have your brakes looked at anyways just lmk and i'll call you when im free up at the shop)
    The Awesome™
    Dec 09 2008
    Wisconsin
    Did you miss the part where he said he had the "same thing" happen a few weeks prior going around a (presumably dry) corner? He tried to fix it by hitting the ESP button. I wasn't inferring he was a moron, just inexperienced. There's a lot of disinformation in this thread for someone at that stage of driving (not to mention younger drivers that may be reading along). Case and point where he posts that the consensus he was getting is that ABS hurts more than it helps in snow. I live in Wisconsin and have had plenty of dry/wet/frozen road experience. ABS is probably one of the biggest advances made in driving safety in a long time as it allows you to retain control of the car during emergency braking. Try locking all 4 up in snow some time and watch your car start to drift sideways. Sure, you can pump, but once you've lost all 4, you can have a bad situation turn worse, quick.
    As for power sliding being a better alternative to ESP, I've yet to be doing 60 down a road where I've lost control and I felt that kicking the rear out was the safe thing to do. I get the feeling that a lot of people think ESP just cuts power (and therefore fun), but it does much more than that. It has the ability to apply brakes on any individual wheel as needed to help bring the car back under control. Want a good example? Try lane changing on icy roads over a 3" thick strip of slush with ESP off -bring extra underoos and the phone number for a tow truck. With ESP on you barely know anything happened.
    Sure, you guys are from a southern state where it's a fluke to get any real snow, but driving in slick conditions helps hone your car handling skills. If you're good when it's wet, you'll be excellent when it's dry.
    Be safe.
    Jul 04 2008
    Seattle, Washington
    yeah i've done both. The feeling difference is slight. I notice in the snow the pulses seem more spread out. So it will slide, pulse, slide, pulse. Same feeling with the pedal kick though. I've never noticed any grinding sound in bad weather though. Maybe i've just never paid attention to it just cause i'm used to it. I'll have to go test the sound.
    - Justin -
