Results 1 to 26 of 26
    Veteran Member Three Rings AudiHolicS4's Avatar
    Apr 16 2008
    Pasadena, MD
    Which clutch to get??
    okay guys time for a new clutch and im just having the problem of deciding which one to get i know there are tons of threads but im still having a couple problems with deciding im stg 2 maybe gonna be stg 3 in the future but for now im just looking for something thats good for a DD and can still get the job done and also what about a flywheel you guys think just getting a resurfaced flywheel is okay? TIA for the input
    -JHMotorsports STG 3
    -Sounthbend STG 3
    -RS4 OEM
    2000 Silver S4
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    Re: Which clutch to get??
    VAST stage 3... i thnk is the same thing as jhm though
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Veteran Member Four Rings Slave IV's Avatar
    Aug 28 2008
    MkV R32, C5 allroad
    CA
    I just got a Southbend Stage 3 Clutch (OFE) and it is very nice but if I were to do it again, I'd go with their puck style clutch with the Sachs Race Cover just to avoid the SAC mechanism and be sure you minimize any chance of slipping. I think it comes in both street and track versions. As for the flywheel, you'll have to see it to know if you can resurface or if you need to replace it.
    Veteran Member Three Rings hoosierchemist's Avatar
    Apr 12 2008
    2000 Nogaro S4
    Indiana
    I talked to Brian at Avalon in Denver about a replacement clutch. I am also stage 2, going 2+ when I change the clutch, and I ended up going with the south bend stage 3.
    Stage 2 Banner Advertiser Four Rings jaybquick@JHM's Avatar
    Aug 24 2005
    Lathrop, CA
    Quote Originally Posted by AMC View Post
    JHM/VAST/SOUTHBEND stage 3's are all the same! vast/jhm just order them from southbend anyways so might as well go to southbend save alittle money. i would not recommend the stage 3 ive had nothing but trouble with that clutch. i do recommend the stage 2 kevlar tho
    Just to clarify and help you with your facts. I don't think you should say stuff as fact that isn't and then call me for assistance with your transmission repairs. I thought we were cool and now you are passing information that you got most likely secondhand as fact. You insinuated that JHM/VAST bought from South Bend. That would mean I did. I DO NOT, I buy from VAST. I am loyal to companies I am in partner with and all I know is that I get them from VAST.
    I get them straight from VAST and I know they get their REAL RS4 pressure plates straight from Germany. Their discs are outsourced and due to loyalty I have never cared to ask or find out from where.
    Here is how I treat my stage 3 VAST. http://jhmotorsports.com/videos/JHM_...Angles_Web.wmv
    Wonderful clutch and I went 11.1 @ 130mph with full interior with it. I think some companies use replica RS4 pressure plates or allroad pressure plates to increase profit margin and pass them as real, this is why many people have had such problems. I have installed tons of VAST clutches on customers cars as well with ZERO comebacks. I have also found in my 16 years of HANDS ON automotive experience, MOST clutch failures are due to improper abuse. I beat on mine hard, but not stupidly. Kind of seems weird but my clutches last longer than many and I treat them harder, it comes down to driving technique.
    Hope this clears things up for a few.
    JHMotorsports AZ tuner spotlight VIDEO
    Check out our 11 and 10 second passes on YouTube
    B8 S5 4.2l - JHM Stage 1 SC Kit (ET: 11.8 @ 119mph) -- B6 S4 - JHM Stage 2 SC Kit (ET: 11.1 @ 128mph) – JHM Nitrous (ET: 12.29 @ 117mph) - JHM Bolt Ons -ALL MOTOR (ET: 12.70 @ 111mph) -- B5 S4 - JHM RS6-R (ET: 10.8 @ 130mph)
    Aug 28 2008
    MkV R32, C5 allroad
    CA
    LOL, I was surprised to see that someone posted that the VAST/JHM clutch was the same as Southbend since I didn't think that was the case....
    Hey Jason, just wondering what your opinion on what the wrong driving technique is that causes premature clutch wear. And since you're here, I was also curious on why only the first two gears are cryoed on a lot of the tranny upgrades out there..Why not do all of them? Thanks for any answers...
    Aug 24 2005
    Lathrop, CA
    Quote Originally Posted by Slave IV View Post
    I think those who slip the clutch excessively. This is a big NO NO. Once you get on boost and if the clutch is being slipped, it will get hot quick. Then they make the mistake of not letting it cool down. I think the best way to be explain it would be "ignorant abuse". Another rule is that any time your clutch shows even the smallest sign of slipping you STOP what you are doing and leave the car alone. I had my stage 3 slip once a long time ago when the track was really sticky on a launch. I didn't try to shift it into second (another mistake) I just backed off at the first sign, went to the pits and packed up and called it a day. Several months later I went 11.1 @ 130mph with that exact clutch that had previously slipped.
    VAST and I have a Sachs Racing pressure plate style clutch with a higher clamp load that is either 6-puck or kevlar. It has a higher clamp load and is quite streetable. We haven't put it on our sites yet since we are putting this clutch on my car soon and one of their in house cars. Once we personally do well with them, we will begin selling them openly. But we have sold several with great results.
    Aug 28 2008
    MkV R32, C5 allroad
    CA
    Thanks for the quick and clear response...I'll ask about the cryo thing again when I'm ready for a new transmission...
    Registered Member Two Rings
    Jan 09 2008
    2001.5 s4
    I would suggest not to go with the kevlar CM stage three and resurfaced stock FW combo. I had this with a FW resurfaced by an indy shop that ate it's self in 4500 miles. Bought a replacement from CM and bought a Vast resurfaced FW (to make sure it was done right, i suspect the indy did it with just a zip wheel) and while better, it still chatters like a MoFo. This is with a rebuilt trans, new slave, new master, and new linkage so I'm kinda set on the idea that the clutch is the issue. BTW this was on k04/997 hybrids only running 11psi so it's not a power issue. Break-in was spot on as well, both times.
    I have driven a southbend feramic (spell?) and love it, thats what I'll be getting next I think, maybe with one of those SPEC FW's with the removable/replaceable friction areas so i don't have to keep buying flywheels (can only be resurfaced once as per vast).
    FYI, I have no experience with the CM stage three from wicked that they say has a different PP or the stage CM stage 3/4 hybrid
    So I'm sure there will be some people telling you to go CM stage three b/c when i researched my clutch kit I found nothing but good reviews. Either they were bullshit (people dont like to admit they spent poorly) or I got the only 2 bad CM stage 3's ever made
    G/L
    Jan 09 2008
    2001.5 s4
    Slave; I know your question was for JHM but when I rebuilt my trans (should have went with JHM and did the work myself btw!) I called Stasis and they said they cryo their 1st, 2nd gears and their input shafts. They do a lot more than that but said thats all they cryo.
    I did this with http://www.nitrofreeze.com/ very nice people to deal with and at the time it cost me about 100 bucks
    Aug 28 2008
    MkV R32, C5 allroad
    CA
    Yeah, I just checks JHM's site and I thought he offered it too but I didn't see it this time. Just wondering why Stasis only cryos the 1st two and not the rest...
    Apr 16 2008
    Pasadena, MD
    Quote Originally Posted by jaybquick@JHM View Post
    dont worry jay i know you guys *and* vast dont mess around when it comes to everything you sell but i just like to get opinions from all sides but your clutch was at the top of my list
    2000 Silver S4
    Apr 16 2008
    Pasadena, MD
    so ive also read that a puck style clutch is not great for longevity and DD can anyone clarify this so i know what my choices should be as for the disc
    2000 Silver S4
    Apr 16 2008
    Pasadena, MD
    Quote Originally Posted by hoosierchemist View Post
    so are you happy with the southbend?
    2000 Silver S4
    Jun 01 2008
    Apopka, FL
    Quote Originally Posted by AudiHolicS4 View Post
    puck styles grab harder and have greater holding power but because of this their lifespan is greatly reduced compared to a full face. The difference can be as much as 10-30K between clutch changes with material's being the same.
    Senior Member Two Rings Splinter's Avatar
    Jan 31 2008
    B.C., Canada
    As far as i know, they only cryo the first two because that's where the problems lie (most prone to failure), and those are the two that take the most abuse... waste of time to do the rest or something.
    2001 S4 6spd black on black- GIAC, Borla, BBS CH, CarPC, rattle can white trim, 034 snub w/ cage, ebay silicone hoses, AWE DTS, obligatory RS4 grill... dreams of Stage 3...
    2000 Audi A4 1.8TQM - RIP March 9/08
    Jun 01 2008
    Apopka, FL
    Quote Originally Posted by ScottyT View Post
    the oe 1-2 syncro was built within such a tight speciication that when you combine most s4 agresssive drivers with it , it would end up seizing from 1-2 power shifts and abuse. There was an updated syncro that was made from a Better material and a looser specification that solved this problem. While it's a good idea to still cyro it for drag Cars and butt loads of power, it's not really necessary for low powered dd's since that is why stasis orginally suggested to cyro the 1-2 syncro.
    Veteran Member Four Rings fixn2xlr8's Avatar
    Apr 11 2005
    Winston-Salem NC
    If I had itto do again stg 3 I woudnt have gone with a lightened flywheel. Syncros dont have time to catch up so I have to give a slight pause beween 1snt and 2nd.
    I went CM stg 3, I might look at a stage 4, 6 puck ceramic next time.
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    i went with a stage 3 clutch from JHM/Vast and resurfased FW, i have 400 miles on the clutch so far and my impressions so far of the clutch are great. The engagement and feel is stock. I can feel this thing grab when i let out the clutch too fast. Cant wait for a few more miles till this thing is broken in.
    Aug 28 2008
    MkV R32, C5 allroad
    CA
    Thanks for the responses...makes sense but I think I'd still rather have it all done if any just because...
    Nov 22 2008
    01.5 S4
    Michigan
    im stage2 for now....dropped a rs4 vlutch from ecs tuning and used a different clutch plate from vast
    Aug 24 2005
    Lathrop, CA
    Quote Originally Posted by fixn2xlr8 View Post
    It isn't the lightweight flywheel causing this, it is worn synchros in your trans.
    All my shifts in my videos are with a lightweight flywheel and a VAST stage 3 clutch, here is one of the best examples of how fast you can shift these from a while ago --> http://audishifter.com/videos/Jaybqu...ifting_web.wmv
    Also you can't compare 2 different companies stage 3s. Not all use the same pressure plates or clutch discs.
    Veteran Member Three Rings slow ride's Avatar
    Apr 20 2005
    New Hartford, IA
    Flywheel/pressure plate weight have nothing to do with the shifting as Jay said. The weight of the disk on the other hand can put more wear on the synchros. The lighter the disk the less inertia and less work the synchros have to do to catch up/down to speed. One nice thing about unsprung disks, but I wouldn't use those on the street.
    00' Laser red S4 RS6 hybrids e85
    02' Corvette ZO6 383 TT 1012whp 990wtq
    02' Tundra
    SOLD 93' AWD Talon 523whp 486wtq
    Apr 16 2008
    Pasadena, MD
    wtf they suspended gregs(2001S4NY) account i wonder what happened well if you read this i deff need help putting it in and NY isnt too far of a drive for me hit me up on my email [email protected]
    2000 Silver S4
    Oct 30 2006
    B8 A4 Avant 6spd
    That was uncalled for..
    -18 718 GTS
    Oct 30 2006
    B8 A4 Avant 6spd
    PM me if you have not reached him.
    -18 718 GTS
