Results 1 to 13 of 13
    Senior Member Three Rings auggy's Avatar
    May 15 2008
    Washington, DC
    Where has all the fluid gone?
    My car drinks about a bottle of washer fluid a week, which I know is abnormal. Is this a common problem with our cars / What could possibly be leaking?
    I'd rather pay a buck or two to fill it up with washer fluid every week than give audi a friggin fortune to fix it .. so hopefully its an easy fix.
    Senior Member Three Rings Burtonrider1002's Avatar
    Jan 14 2009
    Orland Park, IL
    Re: Where has all the fluid gone?
    mine too.
    You gotta remember it runs out so quick because it sprays the headlights and windshield
    Sep 13 2008
    Western Chicago Burbs
    disconnect your headlight washer pumps
    Veteran Member Four Rings 1point8teeNW's Avatar
    Nov 11 2006
    North Webster, IN
    Make sure your pump(s) are seated tightly into the reservoir. Happened to me.
    Current - 2004 Pontiac GTO 6M *FOR SALE*
    Looking for - B6/7 S4 TIP or 6M
    Established Member Two Rings DrJohnnyJones's Avatar
    Dec 31 2008
    03 A4 1.8TQ 5spd
    Frederick, Md
    Quote Originally Posted by B6JoeA4 View Post
    Or just turn your headlights off when you go to wash your windshield... correct me if I'm wrong but I believe it only cleans them when the headlights are on.
    Veteran Member Three Rings pa4ul's Avatar
    Mar 20 2008
    03 Audi A4 1.8T/ 72 Ford F-100
    south
    correct
    Joooe Mamma!
    Deactivated Four Rings
    Sep 30 2008
    n/a
    I thought mine was frozen but I checked today and have nothing but have no light. Weird. I'm shaving the headlight washers off next week when I put my new bumper on
    Sep 13 2008
    Quote Originally Posted by DrJohnnyJones View Post
    thats what i do in the winter but in the summer since there is no point in washing your headlights since there is no salt, i disconnect them.
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    I had mine leak from the rubber seal that seats in the reservoir where the pump plugs in to. Check to make sure the reservoir itself is not warped at that connection where the rubber seal pops in or else it will continue to leak even with a new seal put in there...
    Veteran Member Four Rings mdzaudi's Avatar
    Jul 30 2008
    '03 A4 1.8tqm, 91 Explorer, '05 Arctic Cat M6
    Downtown Denver, CO
    Check all of your lines and connections. There is a 'T' in your washer lines that goes to the headlight washers that you can check just by looking at the inside of your bumper when the hood is open, and maybe at most remove your right headlight. If you've lost a metal clip on your lines, just replace it with a worm clip.
    -Matt
    FCDT Member #1
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Yeah the damn fluid leaks somewhere along the lines to the headlight washers. Mine still leaks but I dont use em much cause Im in Cali... maybe 3 times a year I would need em and they mess up my black paint.... sooo I work around it.
    However the problem was frequent enough that it should have been recalled. I missed knowing that soon enough to get em fixed under warranty.
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    May 15 2008
    Washington, DC
    eh .. I don't wash THAT often and my lights aren't usually on, so it must be the lines. Frig .. I guess I'll give them a check. Thanks guys.
    Established Member Two Rings mmccollum's Avatar
    Jan 07 2009
    White B8 A4 \\ White 04 R1
    Edmonton,AB
    Thumbs up Re: Where has all the fluid gone?
