Results 1 to 4 of 4
    Oct 15 2007
    2000 Audi A4 1.8TQ
    Williamsport,PA
    Angry Key FOB and Locking Problems!!!
    I am about to beat the shit out of my car with an golf club.
    Problems:
    1) Driver's door lock: When I put my key into the lock and try to unlock or lock my car nothing happens. There is no noise from the pump or horn sounding as to verify the car has been locked. The locks do nothing.
    2)Key FOB: Yesterday I went into class and locked my car using the remote and i heard the horn sound. Came out of class the F****** remote doesnt work. So first I changed the batteries and still NOTHING. I have tried all the reprogramming DIY that i could find. The only problem my driver's door lock doesnt work so I used the trunk. I get to step 3 which is lock the car and hit the unlock button and the lights DO flash but it doesnt program the key. I need to get this fixed.
    ANY HELP WOULD BE GREAT!!! I need this solved as soon as possible. I can only lock and unlock my car through the trunk.
    Veteran Member Four Rings Silverstreak98's Avatar
    Dec 11 2006
    Minnesota
    Re: Key FOB and Locking Problems!!!
    All I can think of is that the power locking pump has failed....or is failing.
    Although that would not explain ur remote not working.
    ~Brian
    1998.5 A4 2.8QT
    Established Member Two Rings isramirez21's Avatar
    Aug 02 2008
    audi a4 2.8 1996
    IL USA
    Can't you even open manually with your key?
    You have to be able to open your driver's door with your key.
    The pump as stated above ^ is shut and you might need to replace that, and reprogram your key fob afterward.
    When you try to lock/unlock your door, dont you hear a noise on your trunk? The central locking pump is located on the rear passenger side. Here is a DIY article to replace ithttp://www.audiworld.com/tech/elec131.shtml
    gl
    Oct 15 2007
    2000 Audi A4 1.8TQ
    Williamsport,PA
    Quote Originally Posted by isramirez21 View Post
    Can't you even open manually with your key? You have to be able to open your driver's door with your key.
    gl
    I can not open it manually from the drivers door. The actuator must be broke. I can only open the car from the trunk. The pump functions properly.
