Results 1 to 3 of 3
Thread: CV axle?
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Question CV axle?
    Symptom:
    - Only in the morning on the first outing with the car.
    - Reverse out of driveway, turn the wheel to the right to back out.
    - Put it in first, turn the wheel to the left to start down the street.
    - I hear a clicking in the right front wheel area as I'm straightening out - maybe 4 or 5 clicks then it goes away, and I won't hear it again until the next morning. I can back out of a parking space and do the same wheel maneuvers in the middle of the day, and it won't click.
    CV boot/axle?
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Veteran Member Four Rings 1point8teeNW's Avatar
    Nov 11 2006
    North Webster, IN
    Re: CV axle?
    www.raxles.com
    He'll hook you up for $225 then he'll refund $100 of that once he receives your axle as a core.
    Current - 2004 Pontiac GTO 6M *FOR SALE*
    Looking for - B6/7 S4 TIP or 6M
    May 03 2008
    Orlando
    Re: CV axle?
    Thanks. I saw that URL in several other posts, so that's probably what I'll do if it turns out I need it.
    Kevin W.
