Results 1 to 9 of 9
    Senior Member Four Rings Bravest NY S4's Avatar
    Jan 18 2009
    BKNY
    Coil Pack Nightmares...
    I kept reading about these coil pack replacements, CEL's and misfire codes.... and the s!!! just happened to me: CEL went on, mechanic VAG'd it and misfires came up in 4 cylinders. Plugs are pretty new, but had some carbon build-up on em...Just gonna replace all 8 coil packs, plugs and both conduits just to be on the side safe.
    What is with these damn coil packs, ANY theories
    I'LL BE BACK.........
    Never forget SWAY
    Established Member Two Rings itsjeo's Avatar
    Feb 03 2008
    04 a4 3.0q 6spd
    City of Angels
    Re: Coil Pack Nightmares...
    german engineering. . .
    "Man who stands on toilet is high on pot"
    -Confucius
    Veteran Member Four Rings todd1010's Avatar
    Jun 17 2004
    Jacksonville, Florida
    Haven't bought them yet but I was told that this place has them for about $25 each. And I believe these are the updated versions.
    http://www.genuinevwaudiparts.com/pa...?siteid=214407
    Jacksonville's Premier Paintless Dent Removal
    Got A Ding? Give Us A Ring!
    904.705.DING (3464)
    http://www.dent-technique.net
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    the Q is the latest version that i have seen. And My B5 S4 never had any issue with coil packs. The only think i can think of is that the v8 coil packs arn't bolted down and vibration is getting to them. And the B5's were bolted down. I know vibration can destroy a battery if its not bolted down so y not a coil pack. food for thought. Ill replace all my coil packs when i do the plugs in her
    Jan 18 2009
    BKNY
    Quote Originally Posted by chaos2984 View Post
    I think your right brother, we took em out and they don't seem to have a substantial means of keeping them housed-in too well...
    Never forget SWAY
    Jan 18 2009
    BKNY
    Quote Originally Posted by todd1010 View Post
    Just went and checked that out... its LEGIT thanks bro
    Never forget SWAY
    Established Member Two Rings s4for5's Avatar
    Feb 19 2005
    05 S4 Dolphin without the Fish Mouth & about every other gas powered toy a guy could want..
    Xenonville
    don't wash down this engine
    Moisture creeps into the coilpacs and shorts them out.
    The newer versions have a slightly better seal but a lot of owners have developed failures after having the engines steam cleaned or just washed down.
    Just wipe it down.
    Veteran Member Four Rings littleredwagen's Avatar
    Jan 08 2008
    2019 Tango Red TTRS
    Vero Beach, FL
    Re: don't wash down this engine
    Quote Originally Posted by s4for5 View Post
    Just wipe it down.
    I also think it has to due with the massive amounts of heat the motor produces. I have washed my engine a few times since I replaced my coils and so far so good
    -Matt
    2019 TTRS Tango Red
    2017 Ara Blue S3
    2011 S4 Prestige 6mt Black
    2001.5 S4 EPL Stage 3 Yellow
    2005 S4 Avant 6spd Red
    Jan 18 2009
    BKNY
    Just wipe it down.
    YOUR ABSOLUTELY RIGHT... you know what I realized that the CEL came on right after cleaning the car... this happened on 2 separate occasions, because like an idiot, I sprayed the grille head on!
    Thanks for the input.
    Never forget SWAY
