Results 1 to 32 of 32
    Veteran Member Four Rings gotboost's Avatar
    Nov 04 2007
    Minnesota
    Transmission, Driveshaft and Axle Special Tools
    What are the special "sockets" that I need to remove the drive shaft and axle bolts, and are there any other special tools that I will need to pull the tranny, or install the clutch? I have decided to install my own clutch, Ive done it on a few Honda's and Acura's, so I am willing to tackle this. Are there any tips you guys can recomend to make it easyer?
    Thanks
    Current:
    2002 A4 Avant - Eibach Pro Dampers | Rev Motoring Springs | 034 Motor Mounts | 710N DV | Apikol Snub Mount | 18" S4 Peeler's
    2001 Imola S4 Satge 2+
    2003 A4 GT2871r 303 AWHP 291 AWTQ
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: Transmission, Driveshaft and Axle Special Tools
    Quote Originally Posted by gotboost View Post
    Thanks
    Nice dude,
    Ok for the axles, they call them "serrated" or "triple square"
    http://cgi.ebay.com/ebaymotors/XZN-T...ayphotohosting
    thats the kit I use, not bad for $10. The B5 A4 axles are 8mm but ours are 10, and a 10mm also takes out our seats and flywheel, so that set comes in handy.
    Now, for the driveshaft, I use a 6mm hex with a swivel socket and extension. Your best bet would be to get a ball-end 6mm hex
    http://cgi.ebay.com/ebaymotors/MERCE...ayphotohosting
    Something like that....
    Anyway, you need a 16mm wrench for the bellhousing bolts, make sure you get one with a curved closed end, so you can get to the bottom bolts on the pan
    For the linkage, get either a SHORT 8mm hex socket with an 8mm racheting wrench, or an alen key 8mm and trim the edge a bit to give you clearance. Also, the 8mm alen key will help you for one of the bellhousing bolts
    I think that should be about it , let me know if you have any other trouble, and good luck! Oh, btw just so you know, our transmissions weigh about 120lbs
    - Clint
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    For the driveshaft bolts I would actually reccomend an actual allen key and use like a 6" pipe for leverage. Therefore you can gaurantee not to strip any of the bolts with a swivel socket or some form of extension
    -Sami-
    Oct 29 2005
    10speed
    San Francisco, CA
    touche.. although ball sockets allow a little extra angle without stripping
    - Clint
    Nov 04 2007
    Minnesota
    Awesome, just ordered the triple square bits, Ive got regular hex and the ball hex bits at home, and all the other tools then, I will be doing this in the garage on jack stands, so hopefully I can get the car high enough, and is a tranny jack necessary or will a normal one work to pull the transmission?
    Current:
    Feb 19 2007
    Charleston, SC
    Many of us on here have dont it with just a regualar jack. Having two sets of hands is very helpful though.
    -Sami-
    Nov 04 2007
    Minnesota
    Yeah I will have a second pair of hands, whats the average time to pull and install the tranny, the crappy thing is the car will be down for a while to get the flywheel resurfaced.
    Current:
    Oct 29 2005
    10speed
    San Francisco, CA
    First time, Id give myself about 4 hours out 4 hours in. I can get B6 transmissions out in about 2 hours now, and getting it back in just depends on how quickly it slips into place. Its good that you have an extra set of hands, the minimum without an extra set it 2 jacks
    - Clint
    Veteran Member Four Rings mrbacardi35's Avatar
    Sep 18 2006
    Fresno/Los Angeles, CA
    sorry to thread jack, but what other stuff should be done while the tranny is out?
    Aug 26 2005
    I strongly recommend renting a proper transmission jack, it makes the process of removing and reinstalling the trans a lot easier. With a trans jack, the cradle can be tilted side to side, and the for/aft position is adjustable so that everything lines up properly without a struggle.
    Even if you have help, once you do this job with a trans jack, you won't want to do it again without, it makes a major difference overall and helps insure nothing goes wrong, and minimizes the chance of injury to both yourself, and the car.
    Having two floor jacks, to raise the car onto the jack stands is also preferred, allowing each end of the car to be jacked up evenly with a jack on each side to place the jack stands. In order to obtain enough height for clearance for using a trans jack, the jack stands
    need to be set on risers using 2X4s cut 1' long and stacked up as needed. A hardwood cap between the 2X4 stack up and the jack stand feet, should be used to prevent the riser 2X4s from splitting from the jack stand feet, by the weight of the car. Do not use concrete blocks for risers, as they can possibly crumble unexpectedly without warning.
    Aug 26 2005
    Quote Originally Posted by mrbacardi35 View Post
    Replacing the rear crankshaft seal and the transmission input shaft seal is a good idea while the trans is removed.
    Buncha motorcycles
    Memphis, TN
    thats what i was going to throw in. i tried a 1/2 drive allen socket but the rachet head kept it from sitting perfectly straight in and almost stripped it! used a allen socket with a breaker bar to let it sit straight in and give me plenty of leverage
    pilot bearing puller tool. i rented one from autozone and had to grind the tips to make it fit hehe... i just repainted it flat black and they never knew! the pilot bearing doesnt want to sit straight in at first but just keep realigning it and trying to pound it in and it will eventually find its home..
    get a set of triple square sockets. you only need a 10mm and 12mm for the axles and flywheel. i got a cheaper set and they were nearly stripping. if you are planning it, look on ebay and you can buy some nice quality snap ons for $10-15 each probably. you will need a basic but fairly complete set of wrenches, sockets and extensions. if you dont have that, dont bother.
    other than that, just take your time. its not a crazy hard job. beer will ease the pain from busted knuckles and your abs and neck muscles will be sore as hell after the first day from laying up under that mofo trying to lean up and take shit off!
    good luck , ill be glad to PM you my cell if you have any questions. i had to call sami during mine but he had a 5 speed and the six speed linkages are different from whats show in the DIY guides
    you will feel sooooo proud once the tranny gets back up. it wont be but just few hours from there and you will be done!
    APR Stage 2/AWE Intake
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I concur.
    While you can probably finagle that thing on with a regular floor jack a good transmission jack (or adapter for your floor jack) is the best way to go. Trust me, you don't want that transmission falling on your hand or yourself. I've done that before and it is not fun.
    Safety first. Even if it requires buying new and the proper tools. It also makes the job a lot easier.
    -Doug
    Buncha motorcycles
    Memphis, TN
    very good point doug. That tranny is HEAVY and not a even shape. it takes a tranny jack to hold it safely. i PMed you a few places you can pic one up for about $100 or less
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by Papachristou View Post
    this is why you need a swivel socket.
    Anyway, John is right, Im sure a trans jack makes it easier, but its like having sex, before you do, its not a big deal because you dont know what your missing. Luckily, I havent used one yet so I dont care
    - Clint
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    You dont need a tranny jack, just a good bench press, well make that close grip bench press I personally bench press mine up into place half the time with a friend helping to hold the back and push/guide it into place. It's only 145lbs.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Buncha motorcycles
    Memphis, TN
    wouldnt work either with the 1/2" allen key socket.. not my first rodeo
    Quote Originally Posted by A4 TSCHUSS View Post
    i couldnt get it in with the tranny jack. ended up benching it in. great fun!
    Nov 04 2007
    Minnesota
    cool, thanks for all the tips, i think iam either going to buy a tranny jack or get the adapter from norther tool, have to wait a few more months until iam back from school to do this, also Iam ordering the southbend ofe stage 3 from dthaus
    Current:
    Sep 18 2006
    is this the one?
    http://www.purems.com/images/datapage/06A103171A_dp.jpg
    Sep 18 2006
    do you have the p/n by any chance?
    Oct 29 2005
    10speed
    San Francisco, CA
    yes that is the rear main
    - Clint
    Nov 04 2007
    Minnesota
    When I get my replacement flywheel bolts from Audi, do they come with loctite on them or do I need to apply some, and are there any other bolts that I need to use loctie on (axles or driveshaft)?
    Current:
    Nov 04 2007
    Minnesota
    do we have to change out the pilot bearing, or leave it
    Current:
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Ohhhhh, ahhhhh!
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Aug 26 2005
    Always change the pilot bearing!
    Aug 26 2005
    If the flywheel bolts don't have any locking / thread sealant pre applied, use LockTite "Blue" medium strength compound, including the special pre cleaner/primer spray applied first.
    Besides thread locking, sealing the threads is required to prevent oil leaks from the bolts.
    Nov 04 2007
    Minnesota
    Is there any special puller i need to get the pilot bearing out? also does the new one need to be greased, and were is the cheapest place to get one
    Current:
    Oct 29 2005
    10speed
    San Francisco, CA
    John you wanna hear somehting funny? When I did the 2L I thought the AEG crank had one in it, but it didnt, so for 1500 miles I had no pilot bearing
    - Clint
    Jun 29 2007
    Raleigh, NC
    ^lies!! that's fucking nuts clint.... how did you get away with that one? lol
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Aug 26 2005
    Yes, there is a puller for this, it's an attachment for a slide hammer, called a "blind hole" bushing/bearing puller/extracter. Check with a tool rental store for a slide hammer and the blind hole bearing puller together. The tool may be provided as a Pilot Bearing puller set.
    The Pilot needle bearing needs to be packed with high temp grease, after installation into the flywheel.
    Autozone can lend/rent you this tool.
    Aug 26 2005
    You where lucky! Suprising the clutch worked OK for 1500 miles, without the trans imput shaft breaking or worse.
    Nov 04 2007
    Minnesota
    has anyone used this puller from harbor freight, or will it work, only $10, i would rather just buy one than having the hassle of renting
    http://www.harborfreight.com/cpi/cta...temnumber=4876
    Current:
