Results 1 to 14 of 14
    Jan 15 2009
    canada
    URS4/6 1992-1997 performance chip needed
    Hello i am searching for a good performance chip for my audi s6 1997. I want either TAP stage 2,3,4 chip or MTM or motorsport034 chip.
    thank you for your time.
    Vincent
    Established Member Two Rings YODASFRO's Avatar
    Dec 22 2007
    91 200 20v 91 200 20v avant 92 urs4
    Re: URS4/6 1992-1997 performance chip needed
    Austin
    1990 90 20v 1991 200 20v 1991 200 20v avant 1992 urS4
    Veteran Member Four Rings s6sputnik's Avatar
    95 S6 rs2//13 A6 3.0T//12 S4
    Austin Texas
    Quote Originally Posted by YODASFRO View Post
    I would also stay away from TAP..several friends had BAD luck
    I have had MTM's chip for about 105k and am now switching to MRC RS2 chip.
    MTM was awesome and I have great confidence in Minhea and Bob!!!
    Shawn
    2222 & 620 Austin TX
    // 95 S6 RS2 // 13 A6 3.0T // 12 S4 3.0T
    Feb 10 2004
    2009 A4 2.0T Sedan
    I love my MTM, but then again I don't know enough about the other options to say much else. I do know that these big cars need a software upgrade of some kind to really come alive.
    Aug 07 2008
    Nashville
    is that gtquattro the real deal? stage 3 is $315???? for 325 hp?! sounds like a steal!
    Dec 22 2007
    Quote Originally Posted by iNsaNiA View Post
    Yes it's the real deal if you're interested shoot Ben an e-mail. But to run the stage chip I'm sure you would need bigger injectors/FPR and turbo.
    Austin
    Jan 15 2009
    canada
    Interesting, I sent Ben an email, thanks for you help guy, you guy know a little bit about motorsport034 stage 1+ that comes with 2 chip, vmap, and wastegate spring?
    thanks for your time
    vincent
    Dec 22 2007
    I can't comment on the 034 chip set first hand but I'm sure someone with the chips could chime in.
    Austin
    Jan 21 2005
    WNY
    I have the 034 Stage 1+ chipset. The package comes with: the chips(duh?), 034Motorsport RS2 injectors, 1,9bar wastegate spring, 3bar map sensor(in ECU). I sent them my ECU, they socketed the ecu, installed the chips, installed the 3bar map sensor. Car runs great, nice powerband (3in exhaust and fmic did alot to help too) Car holds 15psi, overboost to 22psi, moves very nice. I might be selling the injectors and the chipset in a month or so, tossing the idea of a turbo change around.
    Senior Member Two Rings branden's Avatar
    Dec 18 2006
    Minnesota
    I've got a MTM Stage 1+ and VMAP for sale guys. Send me an email if interested. I don't check my PM's on here that often.
    http://www.audifans.com/marketplace/...Parts&id=10834
    -Branden
    [email protected]
    Veteran Member Three Rings Sour's Avatar
    Dec 08 2008
    B8.5 Brilliant S4
    was wondering the problems people we're facing from tap chips?
    Established Member Two Rings quattroderrick's Avatar
    Apr 14 2009
    2005 GLI
    Lake Stevens, WA
    Quote Originally Posted by Sour View Post
    I switched from TAP to IA stage 3 and I noticed a huge improvement. Spools up faster, holds boost longer and the curve is nice and smooth. The Tap chipset was completely opposite. Piece of junk in my mind.
    1993 UrS4 | Pearl White | Stebro | Samcos | 2B Coilovers 400/500 | 2B Camber Plates | CF Trim | Euro S6 Taillights | S6 Sport Wheel | Apikol 2.0T coils | IA Stage 3 | SS lines | Delrin Subframe Bushings | Apikol Snub | 034 SD Trans Mounts | DDM 55w 6000k HID | StopTech BBK | Rear BBK | Euro Lenses | Clear Corners | Black Interior swap |
    On the bed: S6 Rear sway, Euro S4 taillights
    Wishlist- Full GT35/40R with VEMS build.
    Dec 08 2008
    B8.5 Brilliant S4
    Quote Originally Posted by quattroderrick View Post
    thanks for the info
    Past
    00' S4 Stage III
    02' S4 Stage II
    95' UrS6 Avant
    Veteran Member Four Rings morris400's Avatar
    Dec 18 2008
    2016 VW GTI, 1994 Audi S4
    Alberta, Canada
    I'm gonna bring this back, I'm looking at a intended acceleration chip. What's your thoughts?
    IF YOU WONT STAND BEHIND OUR TROOPS....TRY STANDING IN FRONT OF THEM!
    2016 VW Jetta 1.4T Daily Driver
    1994 Audi S4 20V Turbo, K24 7400 EFI EXPRESS
    2001 Audi S4 - Gone! Dropped valve cyl 4
