Results 1 to 3 of 3
    Veteran Member Four Rings Charles's Avatar
    Jacksonville
    Sat Radio Clarification
    Ok, I've searched, but I'm still not sure on a few things.
    First, I got my 06 used, and when I press the Sat Radio button, on my non-bose symphony radio, it says "No Sat Radio". Does that mean I have the tuner and I need to get a subscription or that I need the tuner?
    Second, since it's an 06, I assume I have the dual connector and not the single connector.
    Third, if I don't have the tuner installed, that means after I install the4 tuner, I need to flip some switch or something like that. I tried viewing the pdf regarding this, but the link is dead. Can anyone be more specific on what I need to do to let my radio know I have a sat tuner..something with the CANBUS??
    2013 S4 - 200mm crank pulley (3.162 ratio), 034 Stage 2+, USP intake, MercRacing HX, Sachs XTend clutch, SS clutch line, Borla exhaust, gutted cats
    Veteran Member Three Rings Kschroers1's Avatar
    Jan 12 2008
    17' Jeep Grand Cherokee Limited 1942 Edition, 12' A4 Premium S-Line 6spd Quattro
    Roanoke, VA
    Re: Sat Radio Clarification
    No your gonna need a tuner. Go to your audi stealerships parts dept, and with your vin number, write down the part number that you'll need to get the correct module. They cost between 250-500 for one. Get the part number and i rec searching ebay for one or i could sell you mine in 11 months when my lease is up
    2012 Audi A4 Quattro 2.0T 6spd Premium / S-Line / Ibis White/Tan Interior
    2017 Jeep Grand Cherokee Limited Willy's Edition / White
    Veteran Member Three Rings Echo3One's Avatar
    Apr 02 2007
    Phoenix
    Use this write up to see if you even have the module. I just installed the siruis module in my car a few weeks ago. Took less than 30 minutes to install, switch the canbus and calling to activate.
    http://www.audiworld.com/tech/elec.html
    2021 Audi RS7 | Nardo Gray | Cognac Interior | Carbon Optic Package |
    |Eventuri Carbon Intake System |Akrapovic Evolution Titanium Exhaust | CETE Active Air Suspension Lowering Module |
    2010 Audi S5, 6-SMT | Meteor Gray | Prestige Package | Magma Red Interior |
    | APR Supercharger | STaSiS Exhaust | STaSiS Touring Suspension | STaSiS Cast Wheels 20 x 10 |
