Results 1 to 26 of 26
    Senior Member Three Rings therox182's Avatar
    Apr 17 2007
    2001.5 s4 tip
    Los Angeles, CA
    running vagcom on a mac with parallels
    Alright, so I've downloaded parallels so now I can run XP on my mac. I downloaded vagcom 311.2 but I can't get it to work. All of the ports are inaccessible. I think i need to download a driver for the cable (ebay cable), but the CD that comes with it is one of those tiny discs, which I can't be put in macs due to the way discs are loaded, so i have no clue what's on that. What do I have to do to get it to work? I'm hoping someone on this forum managed to get vagcom running on a mac and could help me figure this out.
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Re: running vagcom on a mac with parallels
    you need to get the drivers from the leopard disc, then it will work. You should have just done bootcamp for free
    Apr 17 2007
    2001.5 s4 tip
    Los Angeles, CA
    I don't have lepoard, I'm running tiger. I downloaded parallels for free, so it's not like I'm wasting money. I don't want to use bootcamp preferably because parallels can run XP and OSX simultaneously which would be easier instead of re-booting to get into windows (i'm lazy). but if it works with bootcamp, maybe it's time to upgrade to leopard....
    Veteran Member Four Rings CruzS4's Avatar
    Mar 01 2007
    WK2
    Conshohocken/Sea Isle
    god i hate windows, but to be able to run VAG-COM i guess i could tolerate it. i should look into this
    '17 Ibis White B9 A4 quattro P+ S-Line
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    I realize they run at the same time, my job is to work on computers. It has glitches and it has no many problems, I've used both extensively. And if you have tiger, you probably have a slower processor and that means parallels is going to lag.
    Apr 17 2007
    2001.5 s4 tip
    Los Angeles, CA
    I have a 2.16 GHz Intel Core 2 Duo Processor. It didn't seem to get laggy, but then again I didn't get very far with it. Do you have any advice for what I should do with the parallels, or are you go leopard or go home
    Veteran Member Four Rings SLC_S4's Avatar
    Jul 15 2007
    2001.5 S4
    Utah
    I like VMware Fusion much better than Parallels if you can pick up a copy of it. It seems to work much better with USB and other devices. Really though, if you have an Intel (which you do obviously to be able to run Parallels), I would just run Windows off of Bootcamp.
    Ok, just read the thread, should have done that first. I would definitely upgrade to Leopard and then run Bootcamp. Yeah, it's a little bit of a pain to have to restart in Windows, but you can also use that same drive partition with Fusion or Parallels and so you don't always have to restart, just when you want optimum performance.
    -Seth
    APR Stage 3 - APR Stealth exhaust - APR downpipes - APR Bipipe - APR snub mount - AWE side mount intercoolers - AWE LWFW - RS4 clutch - ITG panel filter - JHM Shifter - Startup Racing Vogtland GT coilovers - Stern adjustable control arms - Fiber Images vented carbon fiber hood - Fiber Images carbon fiber fenders - Recaro Style Topline seats - A bunch of other stuff I can't remember
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Quote Originally Posted by therox182 View Post
    If you have those specs I'm surprised your computer didn't come with leopard. Its up to you though. And yes VMware fusion is also good.
    Apr 17 2007
    2001.5 s4 tip
    Los Angeles, CA
    Quote Originally Posted by SLC_S4 View Post
    do you have vagcom working with bootcamp?
    Apr 17 2007
    2001.5 s4 tip
    Los Angeles, CA
    Quote Originally Posted by nsmith12 View Post
    yeah i bought my laptop before leopard was out and just upgraded everything I could
    Jul 15 2007
    2001.5 S4
    Utah
    Yep
    -Seth
    Apr 17 2007
    2001.5 s4 tip
    Los Angeles, CA
    Yep
    balls. maybe i'll just uninstall parallels and try and get my hands on leopard. Was it an easy install and whatnot? Like did you just install vagcom running windows and it worked right away?
    Jul 15 2007
    2001.5 S4
    Utah
    Yeah, after you get bootcamp installed and set up the drive and install windows, all you have to do is run the vagcom setup while in windows, then plug in your vagcom to the USB port and the car.
    -Seth
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    The leopard install is cake, takes about two hours. The boot camp one is easy too but you need a copy of windows to put on it. It downloads all drivers from the leopard disc though.
    Veteran Member Four Rings Mattgfx's Avatar
    Sep 27 2006
    i run boot camp , and only use XP for Vag-Com also...
    AKA: Bigair
    Sold: 00 Audi S4
    Sold: 08 BMW 135i
    Sold: 11 BMW 328i xdrive
    Sold: 11 BMW M3
    Current: 15 Audi S3
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    if you have any other questions let me know, macs are my thing
    Apr 17 2007
    2001.5 s4 tip
    Los Angeles, CA
    I think i got it to work, i need to run out to the car to check, i'll post back with my results.
    Veteran Member Three Rings Silver streak's Avatar
    Jul 14 2007
    01 S4 stage 3 AWE full kit
    Vancouver B.C.
    Thanks guys, I've been trying to make mine work as well.
    AWE, GIAC, Stasis,KO4s, bla bla bla this is getting a bit ridiculous. I hope it will end soon.
    Apr 17 2007
    2001.5 s4 tip
    Los Angeles, CA
    UPDATE: I got it to work with some help from a friend. So you can use parallels to run it, not just bootcamp. I just needed to download the driver for it and then it was fine from there. Thanks for everyones help though
    Nov 27 2007
    2000 s4 black : 03 600rr Black
    NOVA, VA
    glad you got it to work, I might have to look into parallels or VMware, like you i'm too lazy to reboot in xp with bootcamp, unfortunately it takes under a min to do, (hints why my grandma gave me a pamphlet on adult adhd last week)
    OT but in the spirit of the vag (insert pun here) i was fooling around behind the center console last week, saw the computer port diagram on the ashtray assembly, knew there was no port there but decided to explore, saw a clip and decided that it was what I was looking for knowing full well it was not, pulled it out (insert pun once more), turned out to be the parking brake sensor, now along with my cel, i now have BRAKE on my cluster... just when i think you can't get any dumber you go and do something like this.... and TOTALLY redeem yourself
    Veteran Member Four Rings Boris's Avatar
    Dec 20 2005
    District 7
    i use bootcamp.
    fwiw, I have a 2.16 ghz intel macbook, and I could not get it to work with fusion. There was too much latency. I could access the program, and plug it into the car, but it was unable to retrieve fault codes etc.
    I installed leapord just to get bootcamp (too bad I missed the beta for free)
    anyways, bootcamp works fine, and its not too big of a pita to startup, hopefully you wont need to be vag coming the car too often!
    Feb 09 2007
    00 S4
    MA
    FYI:
    use can only use the newer version of parallels since the older ones (the one I have) does not recognize when you plug things in via USB
    Buy tools, not labor....
    00 Audi A4, 1.8TQ avant, 6-speed swapped (from auto), s4 brakes, uprights, cluster, grill, OEM bmw style 162 wheels, slammed.
    95 BMW M3 drift car: OBD1 S52, gutted, tubed, flares, angle.
    Senior Member Two Rings thebigchu's Avatar
    Oct 24 2007
    2004 Yukon Denali, 2010 Ibis S4 Prestige 6M
    San Ramon, Ca.
    VMWare Fusion FTW.
    2010 Ibis White S4 6M Prestige. Stage 1 (034 Motorsport). ADS, Sports Diff, B&O, Nappa, Tech package, 19" Trispoke.
    SOLD - 2002 Brilliant Black S4 6M ** Stage 1 ** (GIAC-X * JHM "Solid" Short Shifter * 034 DVs/TBB * Avic D3 * Clear Corners)
    http://www.audizine.com/classifieds/...inside-&cat=67
    Active Member Four Rings
    Dec 11 2006
    Boston
    Who wants to give me the 101 on running Windows on my Leopard.
    Stage 3+ RS6's
    Oct 24 2007
    San Ramon, Ca.
    Quote Originally Posted by deb38 View Post
    There is an app already part of your Leopard install called Bootcamp. Run that. It will walk you through it.
    But basically it goes like this:
    Run Bootcamp, and repartition your HD for a Windows. I'd recommend 40-50gb. Not much more cause whatever you use for windows you can't use for mac.
    Then it asks for your XP or Vista install disk and it installs normally.
    Then once you boot into Windows for the first time put in your Leopard disk and it installs all the appropriate drivers.
    Now you have a dual boot machine.
    For added coolness install the app rEFIt. This makes it so you can select which OS at boot up instead of having to select it in bootcamp every time.
    For super added coolness, get VMware Fusion and you can run run your XP or Vista partition in a window within Leopard. I actually use this 90% of the time.
    Hope that helps.
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    To get to the bootcamp program go to applications>utilities>bootcamp
