Results 1 to 7 of 7
    Veteran Member Three Rings ziggituning's Avatar
    Mar 04 2008
    04 B6 1.8T Q 6 spd
    Brake vaccume sensor.
    Anyone ever had any issues with this part. It is next to the brake booster in the vac line from the intake to the booster. I was wondering if it went bad what would the symptoms be. Codes and physical symptoms.
    PARTS FOR SALE: LW Crank Pulley, OEM injectors, ABT rep grill, OEM Intercooler, PM me.
    For your OEM HID D1S/D2S/D3S and HID conversion [Headlights/Foglights], and Interior/Exterior LED needs, send me a PM![/SIZE]
    Feb 17 2005
    Sarasota, FL
    Re: Brake vaccume sensor.
    Doesnt exsist in the B6
    Mar 04 2008
    04 B6 1.8T Q 6 spd
    But I have one on my 03 B6 1.8T?
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by ziggituning View Post
    You shouldnt ...
    Post a pic
    Oct 29 2005
    10speed
    San Francisco, CA
    pretty sure ive pulled the motor out twice and never seen that
    - Clint
    Feb 17 2005
    Sarasota, FL
    haha
    Ive done plenty of work on 02's, 03's, and mine (04') and never once seen one on an A4, not even a B5. Only car I have seen with that is the Mk5 R32
    Mar 04 2008
    04 B6 1.8T Q 6 spd
    It is behind the firewall, next to the brake booster (or as audi calls it brake servo), if you follow the vac line from the intake to the firewall, then otherside to the bosster it is on the vac line going into the booster.
    My bad it is only on tip (auto) equipped cars, it is part of the brake vac system, which is not used on manual trans cars. My 04 6 spd does not have it, only the 03 TIP.
