Results 1 to 23 of 23
Thread: 18x9.5
    Registered Member Two Rings walkerkd's Avatar
    Aug 10 2008
    Fort Worth, Texas
    18x9.5
    im planning on running this on all 4 corners with 32 or 35mm offset
    tires will be 225 35 18s or any suggestions?
    or should can i run a 30mm offset?? any suggestions are welcome or am i being a bit stupid to think i can pull this off.
    USP CLUB MEMBER #122
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    Re: 18x9.5
    You are being stupid.
    Jun 30 2007
    Raleigh, NC
    Re: 18x9.5
    what about 18x11?? lol
    and no i'm not kidding
    (quit being a debbie downer winston!)
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Veteran Member Four Rings forevraudi's Avatar
    Sep 01 2008
    San Diego, CA
    Re: 18x9.5
    too wide for the front
    Jun 11 2005
    Vancouver, BC
    Re: 18x9.5
    Quote Originally Posted by B6Lovin View Post
    Well I obviously missed the part of running a lift kit too.
    Aug 10 2008
    Fort Worth, Texas
    Re: 18x9.5
    haha.. ok i came over to the dark side from the 240 scene. so yea i fitment fool!! anyway so you guys stick with 8.5s or what everything i read says that. just seeing how far i could push it. anyway whats the magic aggressive offset???
    Jun 11 2005
    Vancouver, BC
    Re: 18x9.5
    18x8.5 ET32 is the magic setup for the flush to the fender look.
    Max tire width is 235
    You can run a 18x9.5 ET32 in the rear if you adjust your camber to -2.0deg and tweak the toe settings.
    Aug 10 2008
    Fort Worth, Texas
    Re: 18x9.5
    ok so with that said 35mm offset in the rear will keep camber and toe closer to stock got it. so 32 is the lowest offset without flares?
    Jun 11 2005
    Vancouver, BC
    Re: 18x9.5
    I ran 19x8.5 ET30 but you will have a bit of rubbing on the fronts with a 235 series tire.
    Veteran Member Four Rings eurogruppe's Avatar
    Jun 05 2008
    2021 RS6
    Cleveland, OH
    Re: 18x9.5
    how about a 19x8.5 et35 with 255/35/19's?
    21' Audi RS6 | E30 M3 | 996 Turbo | Corrado SLC | IG: @stevedavid993
    Jun 11 2005
    Vancouver, BC
    Re: 18x9.5
    Well if you only pull in the wheel 2mm but add 10mm of tire on each side I don't think it is going to work.
    Veteran Member Four Rings got boost.'s Avatar
    Jun 03 2007
    california
    Re: 18x9.5
    Quote Originally Posted by eurogruppe View Post
    I rub on stock 02 sport suspension with 235/35/19 on 19x8.5 et 35.
    l BBS l FORGE l STERN l VMR l ER l SPEEDTUNE l
    Jun 05 2008
    2021 RS6
    Cleveland, OH
    Re: 18x9.5
    only reason im asking is because i just ordered 19x8.5" VMR V710's with the et35. I used to have the V708's in 19x8.5" et38 running 245/35/19 and they were fine, actually still had some room so spare, not much, but it was there.
    Veteran Member Three Rings gotdubd's Avatar
    Sep 28 2006
    Hell.
    Re: 18x9.5
    18x8.5" et35 225/40/18
    18x9.5" et40 235/40/18
    Jun 05 2008
    2021 RS6
    Cleveland, OH
    Re: 18x9.5
    thats tits
    Sep 28 2006
    Hell.
    Re: 18x9.5
    theyre for sale.
    tell all your friends
    Jun 05 2008
    2021 RS6
    Cleveland, OH
    Re: 18x9.5
    all my friends either have muscle cars or bmw's and vw's that arent 5x112 lol, although my mom does have a benz, but she would never go for it :). if they were 19's i would def take them off your hands
    Sep 28 2006
    Hell.
    Re: 18x9.5
    tell your vw friends with mk4s that with adapters these look super cool
    Jun 05 2008
    2021 RS6
    Cleveland, OH
    Re: 18x9.5
    word
    Senior Member Three Rings Xoticautowerks's Avatar
    Jun 02 2008
    04 Black S4
    Kings Bay, GA
    Re: 18x9.5
    Quote Originally Posted by gotdubd View Post
    How much is that dropped and any rubbing at all. my buddy has same size rims and tires except the rears are 255, wanted to know if I might be able to take them off his hands
    Veteran Member Four Rings Audized's Avatar
    Oct 22 2006
    Eh?
    Re: 18x9.5
    Quote Originally Posted by got boost. View Post
    I didn't rub with 235/40/18 on 18x8.5 ET35. What tires?
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '05 MV Agusta F4-1000
    MD
    Re: 18x9.5
    A 9.5 rim will only fit properly with atleast a 44-45mm offset, regardless of suspension setup.
    Current: '23 etron-GT | Prestige
    Previous: S5 | Prestige
    Sep 28 2006
    Hell.
    Re: 18x9.5
    Quote Originally Posted by Xoticautowerks View Post
    My Eibach Prostreets are just about flat bottom in the rear. There was 3 turns or so left...
    No rubbing unless I had 2 backseat passengers.
    There is no way you could be that low on 255's
