Results 1 to 20 of 20
    New Member One Ring
    Dec 26 2007
    I think I want a B7 A4
    Okay well after going back and forth the past few months on what car to buy, from the 335xi to the 08sti/wrx and 08 R32, and I keep coming back the audi. Well after lots of thought, I really don't need the power of those cars and don't need such high payments. After driving in my friends chipped 1.8t gti, I figured that's plenty of power for me, and I can get that and more from the A4 2.0T. Plus I think the B7 looks better than all those cars, and theyre def more comfortable and civilized than the Subies.
    So after lots of though I am thinking of getting the B7 A4 2.0T with quattro and 6mt. My question is, how much whp am I looking at from just an exhaust and chip/reflash? Would if be comparable to lets say a stock WRX or a 08 R32? How is Audi with ecu upgrades and warranty? Thanks!
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Re: I think I want a B7 A4
    They are not comparable to those two cars, you get roughly 40-50HP to the crank with a chip, and 5-15hp for a exhaust, another 5-15hp for a testpipe, roughly nothing for an intake
    Jan 09 2009
    FL
    Go with the b7.
    I just bought my pre-owned certified from Audi. It's an '07 with 24k miles. Mint mint condition. Got it for 20k + TTT.
    Veteran Member Four Rings A4A4A4's Avatar
    Jun 02 2008
    Victoria, Canada
    Good choice on the A4.
    A chip will add around 50 bhp and about 85 lb-ft of torque (depending on which brand you go with). An exhaust won't add a whole lot of power (5-15 bhp I believe), but it will give you a nice mean sound.
    It'll probably produce more power than the R32 and wrx, but you have to take in account the weight difference between the three cars.
    As for the warranty issue, yes most dealerships will void your warranty if they find out you're chipped. To combat this the chip tuning companies offer ways to "hide" the chip for when you take your car to the dealership.
    -Cam
    New: MK6 Volkswagen GTI
    Old: E92 BMW 335i
    Older: B7 Audi A4 2.0T Quattro
    Jan 10 2007
    VA
    If a chipped 1.8T GTI is plenty of power for you, you will be satisfied with a chipped A4 2.0T. A chipped A4 will be very comparable to a stock R32 in terms of strait line performance. It will have more torque so it will feel more powerful than the R32 though.
    The new WRX, STI, and 335ix will still be quiet a bit quicker than the chipped A4 though. The new WRX has 265hp, and you know the STI and 335 have 300+.
    Audi (as with BMW and many manufacturers) tend to be void-happy when it comes to mods and warranty. ECU reflashes are transparent to dealers and you can even flash your car back to stock before you take it in. If a dealer knows what they're doing they can find out if your car has been reflashed, but they wont go to the trouble unless something major breaks that ordinarily shouldn't. In the end, it all varies dealer to dealer. But a majority of owners have no warrranty issues even being chipped.
    Nov 30 2008
    2015 Golf R
    Parkland FL
    I have both the B7 and an 08 R32. While I love the driving dynamics of the R32 I think the Audi is a little quicker now with the chip and exhaust. The tranny in the R32 is awesome. It is too bad Audi won't put dsg in the A4 (I know it is coming in the new S4) when VW has said they will virtually phase out conventional autos in favor of them.
    2008 Ibis White S-line Ti CVT GIAC X-Chip, RS4 Rear Sway Bar, Eibach Pro-Kit Springs and Pro Dampers, 10mm front 15mm rear spacers, Carbonio Air Intake, APR Cat Back Exhaust
    May 03 2008
    06' B7A4 20T Non-Sline
    Monterey, CA, 93940
    Quote Originally Posted by Vinscap View Post
    I thought the paddle shift Audis were DSG... :/ I know for a fact its different then just the reg. tiptronic.
    Jun 02 2008
    Quote Originally Posted by 06B7audiA4 View Post
    The B7 A4 doesn't have DSG. It's just Tiptronic with paddle shifters.
    Nov 30 2008
    2015 Golf R
    Parkland FL
    I have a CVt with S-Line and it has paddles. There is currently no A4 with DSG. A3 has and I believe TT has. This is because they are MK5 based and use the same engines and trans that VW uses.
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    The s-line tips have paddles tho
    Veteran Member Three Rings Subaru71's Avatar
    Jan 15 2008
    2010 DGM Impreza WRX
    Chino Hills, CA
    to the OP, I just dynoed higher than my old STi when it was stock... and my audi is still on the stock turbo :D
    2008 Phantom Black TQM
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    Buy the 335xi and up the boost and forget about it :)
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Veteran Member Three Rings CX-7&A4's Avatar
    Dec 09 2007
    CX-7 AWD/A4
    Foreclosure Captial of the US
    Stay away from the Subaru's with turbo engines, rod knock will occur.
    The 2.0T already feels faster than it is, and with a chip it should feel just as fast as an R32.
    07 Mazda CX-7 AWD
    06 Audi A4 Fail2Trak CVT - TRW Front/Mintex Redbox Rear
    Mar 05 2007
    2012 BMW 135i M Sport, 2008 Jeep Liberty
    San Antonio, Tx
    Everyone's leaving out the Fuel Pump upgrade. Take it Stage II plus Fuel Pump and you'll be at approx. 280 crank HP (according to APR), throw in an intercooler for a little bit more and you're pretty well set.
    Papachristou: i just said "yeah well you are still driving a neon, and she still wants to ride in my car"
    Veteran Member Four Rings elwigglero's Avatar
    Sep 04 2008
    B7 S4 DTM, B7 A4 2.0T Ti
    Lansdale, PA
    Currently only available on cars with haldex quattro. A3, TT, R32.
    Veteran Member Four Rings vtracer20's Avatar
    Apr 14 2008
    Milton VT
    DSG is a Dual clutch system for VW's, audi's is called sportshift or sporttronic or something similar. Just making sure you guys are using your terminology correctly.
    2007 A4 S-Line / Ti Pkg / Quattro / Bilstein Pss9 / JHM Short shifter / GIAC X+ chip / RS4 rear sway bar / 20% rear tint / 10mm front 15mm rear spacers / Forge DV / DTM CF replica rear lip spoiler / DTH CF roof spoiler / Cupra R front spoiler (not on) / Infinity BasslinkII sub
    looking for: CF front lip / S4 alum mirror hosing
    Jan 15 2008
    Chino Hills, CA
    Quote Originally Posted by CX-7&A4 View Post
    lol whats "rod knock?" and why is Subaru rated so highly on their reliability?
    Dec 09 2007
    CX-7 AWD/A4
    Quote Originally Posted by Subaru71 View Post
    lol lol olol olllllll http://www.stiblog.com/articles/2009...ubaru-failure/ lol i dnt kno y mus b fake
    07 Mazda CX-7 AWD
    Veteran Member Three Rings johntesi's Avatar
    Jan 17 2008
    Evolution X
    Texas
    Shameless self promotion:
    http://www.audizine.com/classifieds/...ate=1217381211
    Car meets your above listed criteria!
    Mar 19 2008
    while we're bashing subaru, lets not forget about the dangers of cam follower and camshaft wear from the upgraded HPFP in our audis. Be warned!
    2019 S5 BO.SS
    2009 R8 6 Volt :)
