Results 1 to 17 of 17
    Senior Member Three Rings CAA's Avatar
    Oct 26 2008
    2010 Brilliant Black S4
    NoVa
    Which tires wear faster - front or rear??
    At inspection I had to replace my rear tires. My front are 85-90% and I asked Costco to mount the new tires to the front and move the fronts to the rear. Their policy is to always put the newest tires on the rear of the car. They said that you can bring them back for rotation any time you want, but that is their policy.
    My question is, would I be better off moving the new tires to the front? My gut feeling, (if it's like my Carrera 4 was) is that the bias is to the front wheels. Any advice appreciated. Thx.
    Veteran Member Three Rings SebringSilver's Avatar
    Oct 04 2006
    TT RS
    Vancouver, Canada
    Re: Which tires wear faster - front or rear??
    Quote Originally Posted by CAA View Post
    My experience with my 2006 S4 is the fronts wear quite a bit faster than the rear. Get them to put the new tires on the front.
    Currently Driving: '18 TT RS | '18 Velar P380 HSE First Edition
    Gone and Missed: '18 TTS | '14 991 C4S | '11 R8 V10 | '09 R8 V8 | '09 C63 AMG | '06 B7 S4 | '94 NSX | '92 NSX
    Oct 26 2008
    NoVa
    Thanks for the quick reply buddy - appreciated.
    Account Terminated Four Rings
    Jun 02 2008
    2007 S4 MT6; B8 A4 2.0T Avant
    Toronto, Ontario, Canada
    I would guess rears because my car is 60% biased to rear wheels, however the braking force and sheer weight of this car up front MUST wear the fronts out.
    make a poll
    Veteran Member Four Rings snopyro's Avatar
    '08 TT 3.2q Roadster (for sale), '20 A7, DC Taco, SV650s, lots of snowboards
    Yes, the quattro tires wear out like a front wheel drive car. Put the tires with the most tread on the front of the car.
    Dec 26 2007
    1999 Panoz AIV roadster
    New Market, MD
    ...My question is, would I be better off moving the new tires to the front? ... Any advice appreciated. Thx.
    If you have Quattro, you need to be careful about that. See link.
    http://www.tirerack.com/tires/tirete...jsp?techid=18&
    1999 Panoz AIV
    Oct 26 2008
    NoVa
    Yep - thanks for the link. I understand what Tire Rack is saying but to scrap tires with 3k miles on them to match all four is stupid.
    Veteran Member Four Rings yung turbo's Avatar
    Feb 19 2008
    2005 A4 1.8TQtip-2011 A4 2.0tQAuto
    NYC/DE
    front always wear faster unless your RWD because more stress is put on the tires i.e. turning left and right(camber wear).
    TuRboK1ng
    You Are All Witnesses
    And The Yankees WIIIIIIIIIIIIIIIIIIIIIIIIIIN
    The Yankeeeeeeeeeeeees WIIIIIN!!!!!!!!
    Veteran Member Four Rings Cargo8's Avatar
    Dec 06 2006
    Fronts probably wear faster due to the weight / braking.
    I would also say you wanna have the better tread on the fronts in an AWD car considering if you get in trouble, Front wheel grip is more useful than Rear wheel grip [awd, front pulls out of slide/trouble]
    Dec 05 2006
    So. Cal.
    It's a liability thingy!
    Tire installers want to limit their liability so they are required to place the new tires on the rear of the car to prevent the car from spinning out.
    Putting the newer tires on the front is a more logical choice as the fronts provide the grip needed to accelerate and turn and they wear faster.
    Veteran Member Four Rings serumk's Avatar
    Dec 31 2008
    2002 A4 quattro
    Kansas City
    The reason tire installers want to put new tires on the rear is that it reduces the likelihood of oversteer, which is a condition most of today's drivers are unfamiliar with, and more likely to get in a nasty wreck as a result of.
    If it was me, I'd want the new tires on the rear. Oversteer is nice on the track, but I'd definitely prefer a push on the street, lol. Tell me, how many times have you used the gas pedal to get you out of a skid?
    Dec 06 2006
    yeah, but in an AWD car the front wheels are more important than the rears, since they can pull you out of any trouble, and power is thrown to the front during a slide. They also, you know, turn the car?
    Registered Member Two Rings
    Jan 03 2007
    Germany
    brand new tires have a buildup of resin from the molding process, that's why it is always recommended to drive easy for the first few hundred miles. of course, not everyone heeds that info, so if the installers put them on the front and someone takes a turn at speed, they may end up going straight and Cosco doesn't want to risk that. drive the car around for a few weeks, then rotate the tires to the front; b6/b7 platform is something like 58/42 split since the motor is in front of the axle. between that, the front wheels being driven and the fact this car is fun to take corners fast in make for the fronts to wear more quickly than the rears.
    Some people are like Slinkies - not really good for anything, but you still can' t help but smile when you see one tumble down the stairs.
    Dec 31 2008
    2002 A4 quattro
    Kansas City
    Quote Originally Posted by Cargo8 View Post
    I recognize your thinking, and I'm not trying to start a fight, so I'm sorry if I offended you.
    In an AWD car, depending on how the torque is distributed, different wheels will play a larger role in a car's acceleration, but in braking and cornering, all tires play a very important role. The only reason installers want to put newer tires on the rear is that most drivers find it easier to control understeer (front of car loses traction before rear) than oversteer (rear of car loses traction before front). As others have said, they're just trying to minimize their liability by making the car as easy to drive as possible, for the largest number of people possible.
    I recognize that front wheels turn the car. That's exactly what I'm saying. In a situation where someone is turning, most drivers find it easier to correct understeer than oversteer. If you prefer a car with a tendency to oversteer, good for you -- put your new tires on the front.
    I realized I hadn't answered the OP's question -- I would assume the front tires wear faster.
    Dec 06 2006
    ^ word sorry, wasnt trying to argue either
    Veteran Member Four Rings Monchichi8's Avatar
    Jul 03 2004
    2004 S4, 2005 Grand Cherokee Hemi
    Boulder,Colorado
    Quote Originally Posted by yung turbo View Post
    BINGO!
    Oct 26 2008
    NoVa
    Thanks for all the replies - nice to have my guess confirmed.
    Cheers
    -CA
