Has anyone had trouble trying to remove the 8mm hex bolts that connect the calipers to the axle.
I could not get them to move for the life of me. I am guessing I will need a breaker bar with a 8mm hex socket suggestions?
Also Bentley says to always replace those bolts has anyone used the bolts again?
i will be replacing rotors on the rear and installing s4 fronts so need to know if i need to go out and buy the calipers bolts for front and rear again.
I do not remember replacing them when I did the front last time.
