Results 1 to 18 of 18
Thread: Headlight Bulbs
    Registered Member Two Rings soccerstargt17's Avatar
    Jan 21 2007
    Cupertino, CA
    Headlight Bulbs
    Hey everyone,
    i wanna get some brighter more blue purple light from my low beams. I have a 2000 A4 1.8T. I'm pretty sure that i have the one piece projector headlights. Anyone know where i can get some bright bulbs and how much they would cost?
    Thanks
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    Re: Headlight Bulbs
    you need an HID setup and I would say don't go over 8000k, best light output are 4300k and 6000k, and 8000k is pushing it but will give you blue lights for sure.
    Veteran Member Four Rings InTTruder's Avatar
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    Re: Headlight Bulbs
    DO NOT get wild @$$ high K-value bulbs. Get some good euro-spec Phillips or whatever. Purple bulbs really suck, don't give good low-beam pattern or depth. Rice-@$$ purple really sux to drive, and to drive against. PERIOD.
    The Spartans do not enquire how many enemy there are. They enquire only where they are.
    Jan 21 2007
    Cupertino, CA
    Re: Headlight Bulbs
    Quote Originally Posted by njm23 View Post
    so how much would that cost me to do?
    Feb 28 2007
    04 a4 USP ; ATS
    Re: Headlight Bulbs
    since you have one piece lights, basically will cost how much you are willing to spend. Assuming your bulbs are H7, you can spend $70 shipped on a "cheap" kit or spend $300 on a good kit. Do some searching you will answer every possible question you could have. VVME is a cheaper kit, then you have more high end kits.
    Veteran Member Three Rings a4937's Avatar
    Aug 14 2008
    Ohio%20
    Re: Headlight Bulbs
    8000k are what is in my avatar.
    Veteran Member Four Rings TighTT's Avatar
    Feb 21 2006
    Widebody'd avant with AZR 3.0 TTE 950+
    NJ/NYC
    Re: Headlight Bulbs
    Here ya go....
    http://www.ddmtuning.com/hidkihidbuhi.html
    DDM 35 Watt Slim Ballast HID Kit
    Bulb Type: H7
    Bulb temp: Either 5000 or 6000
    50% Blood
    50% Sweat
    50% Forced Induction
    Thats 150% motherf*cker.
    Veteran Member Four Rings wesleyfbm's Avatar
    Aug 25 2008
    the 01 a4 tttt and my BMXer
    rhode island
    Re: Headlight Bulbs
    i have vvme.com hid kit and that was $66 shipped. works fine and bright as hell.
    Dec 05 2007
    Re: Headlight Bulbs
    You have one peice projectors and just get the DDM tuning ones. They are US made w/lifetime warranty on bulbs and ballasts vs VVME which has 2 years and is an Overseas product. Plus if there is a defect, shipping cost should not be a nuisance. As for temp, I would not go beyong the 6000K personally. I have 55w 5000K on mine (Retro-Solution).
    Jan 21 2007
    Cupertino, CA
    Re: Headlight Bulbs
    Thanks a lot for the advice. I think i will be going with the ddmtuning ones. Is there any way to get 55w ones vs 35w? Does it make sense to get the 55w ones?
    And one last question, how hard is the installation?
    Thanks agaiin
    Veteran Member Four Rings Kronic Budz's Avatar
    Oct 01 2007
    1997 A4 2.8 QM
    San Diego, California
    Re: Headlight Bulbs
    Quote Originally Posted by a4937 View Post
    lol yea 8k is pushing it
    1997 Audi A4 2.8 QM black on black
    bilstein sports w/ vogtland sports ~ S4/sport sway bars ~ 17x8 Bremmer Kraft Br05 wheels et33~ BF G's Sport COMP 2's 225/45/17 ~ Custom Exhaust ~ CAI ~ Ebay SS ~ SS brake lines + EBC red stuff ~ 35% tint/70% front tint ~ face lift headlights w/ 5000k HID + tails ~ blacked out grill trim~ kenwood mp3 ~ Polk comp 5.25" Front mm speakers ~ Infinity REF 6.5" rear speaks ~ 10" Rockford Fosgate p2 in sealed box ~ ED nine.4 4ch. amp powering woofer/polks[/I]
    Registered Member Three Rings
    Sep 30 2007
    has too much crap to fit a car
    Upstate, NY
    Re: Headlight Bulbs
    dont go with 55 watt HID in the stock projectors. The chrome coating on the inside of the projectors is very sensitive to heat and 55 watt aftermarket HID bulbs get way too hot... you'd end up with probably less light output over time.
    Jan 21 2007
    Cupertino, CA
    Re: Headlight Bulbs
    How much more light will i get from a 6000K or 8000K HID compared to my current stock projectors?
    Jan 21 2007
    Cupertino, CA
    Re: Headlight Bulbs
    How come some people say that 55w is too much and others don't? I would like to go with the 55w, is it safe?
    Dec 05 2007
    Re: Headlight Bulbs
    I have no issues with the 55w ballast and halogen housing (Valeo Ecode Halogen). It is the chrome housing that wil have a tendancy to not be able to handle the extra heat. Stock bulbs are 55w, and 35w HID will have a greater light output. 55w HID has a brighter output than the 35w.
    Jan 21 2007
    Cupertino, CA
    Re: Headlight Bulbs
    So is it safe with my stock headlights?
    Full APR exhaust, APR chip, Neuspeed Short Shifter, AWE Boost Gauge, Koni Coils, Vogtland Springs, Hyperboost Valve, Intake, Sport Clutch, Polk Front Speakers, Harmon/Kardon iPod Integration, Painted Lowers, Clear Corners, Debadged
    ...waiting on HID lights
    Dec 05 2007
    Re: Headlight Bulbs
    ^Yep. As long as they are halogen or xenon headlamps, there should be no issue. Chrome housing headlamps can melt due to the extra heat.
    Jan 21 2007
    Cupertino, CA
    Re: Headlight Bulbs
    thanks for the help. Will be ordering some soon.
