Results 1 to 28 of 28
    Veteran Member Three Rings JaVa's Avatar
    Jan 07 2007
    01 A4 2.8, 85 Yota, Isuzu
    anyone running 18x7.5 wheels?
    i want to see how skinny they ook. the whees i want have been discontinued in 8.5 and only 7.5 is available still :( anyone running 7.5 with a 235? have pics?
    NWQuattro - NorthWest Audi Group
    ----01 A4 2.8 QS Tip |GIAC|Zapco|Alpine|Dension|Tint|
    Veteran Member Four Rings JumboBlack1.8's Avatar
    Sep 16 2006
    '98 528i
    Boston/West Hartford, CT
    Re: anyone running 18x7.5 wheels?
    I used to but I don't have any good pictures to show how "skinny" they are.....on a 7.5" rim, a 235/40 tire is REALLY beefy
    on a 18x7.5
    2000 Audi B5 S6 ** 4.2L 40v S6 6spd - http://www.audizine.com/forum/showth...n-s6-4-2L-swap
    Veteran Member Three Rings 1NaudiA4's Avatar
    Feb 13 2007
    98 A4
    Chicago
    The Volks I just got are 18 by 7.5 with 235 tires and I think its just the right amount of rim protection.
    Jan 07 2007
    Quote Originally Posted by 1NaudiA4 View Post
    sweet ill go look at your pics agian
    Apr 22 2007
    Riverbank, Ca
    By contrast my 18 rs4 reps are 8.5 running 235's. and are Just the right amount of stretch to maximize the tire.
    Jan 07 2007
    i would get 8.5 if it were available
    Jan 07 2007
    they look a litte skinny but not bad.
    Quote Originally Posted by JumboBlack1.8 View Post
    waht size are those? 225?
    Sep 16 2006
    '98 528i
    235/40/18 michelin PS2's
    Apr 22 2007
    Riverbank, Ca
    235's on 8.5's. Dont have very good pics, but you can see how it fills out the rear very well..
    Jan 07 2007
    i know but the 8.5's arent available......
    Apr 22 2007
    Riverbank, Ca
    But you should look at other rims that have 8.5 available...
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    lol, he will get what he wants.. If he wants to fill out and make it flush, well that is why they make spacers. I have a pic of my 7.5 wheels somewhere, ill dig it up.
    Jan 07 2007
    im looking on tire rack on a tight budget and the ones i like have been discontinued in 8.5 and i cant source them anwhere.....
    these
    Jan 07 2007
    yes spacers will prob be ordered later on. it is a 2.8 tip so its not a huge performance machine and i dont NEED more tire on the road per say :( and i did just pick up a dedicated auto x car,
    Jan 07 2007
    its between those and 18x8 black RS6 reps
    Veteran Member Four Rings VTAudiA4's Avatar
    Oct 20 2007
    andyrew....whats the et on those 8.5 rims in your pic?
    Apr 22 2007
    Riverbank, Ca
    I honestly dont know. Whatever the standard reps are...
    Apr 22 2007
    Riverbank, Ca
    ET35
    Feb 13 2007
    98 A4
    Chicago
    Don't the skinnier wheels usually have a lower offset to have it stick out the right amount?
    The 7.5's in my thread have a et30 and they sit just about flush with the fenders.
    Jan 07 2007
    these are et35 still, but the back spacing is diff.
    Apr 22 2007
    Riverbank, Ca
    So you'll need a 5mm spacer to get the ET30 backset.
    Feb 28 2007
    04 a4 USP ; ATS
    ^^ your not doing it right. Yes it will be an et30 rim, but 18x7.5 et 30 and 18x8 et30 will fit completely different. The 18x8 rim will stick out 6mm more and will be in 6mm farther. Your 18x8.5 et35 will stick out 8mm farther then the 18x7.5 et 30.. He will need about 15mm spacer to get it somewhat flush.
    Jan 07 2007
    well it depends on the backspaceing on the diff rims
    Feb 28 2007
    04 a4 USP ; ATS
    ^^ the "back spacing" as you call it is really the "offset".
    edit: maybe this will help you out, should help you understand things a bit more.
    http://www.getahelmet.com/jeeps/tech/backspace/
    http://www.1010tires.com/WheelOffsetCalculator.asp
    Jan 07 2007
    so here is waht tire rack says for the 18x8.5
    Offset: 35mm
    Backspacing: 6.18"
    Bolt Pattern: 5-112
    and the 18x7.5
    Offset: 35mm
    Backspacing: 5.70"
    Bolt Pattern: 5-112
    Feb 28 2007
    04 a4 USP ; ATS
    Yes, because one rim is 8.5" wide and the other 7.5" wide, which is why they are different. It is referring to your inner clearance, which changes with diff. width wheels and offsets. Obviously the 7.5 will have a bit more space since it is a skinnier rim. You can't "change the backspacing" of the rim without changing either the width or offset. I wouldn't pay attention to the "backspacing" simply because all you need to knwo is the width and offset. That will tell you exactly where the rim will sit.
    Make sense?
    Jan 07 2007
    yeah now that im awake it makes perfect sense........ i dotn want to run spacers!
    Veteran Member Three Rings Euro's Avatar
    Sep 18 2006
    Bimmers
    Portland
    I ran 225s on my 18x7.5s
