Results 1 to 6 of 6
    Veteran Member Three Rings ZEM930's Avatar
    May 12 2008
    2006 Audi A4 Quattro
    Orlando
    Snub Mount Questions
    ECS Snub Mount
    Ok so I read the "how to install" on the FAQ link. I thought you had to take off the front bumper though? My friend told me you had to but he had a B7 S4. Is this true or is it as easy as the DIY says it is?
    Also any advice or things to watch out for on the install? Thanks!
    -Andreas
    Established Member Two Rings I495 Bandit's Avatar
    Jan 08 2008
    01 St3+VW Jetta/06 A4 S-Line
    NoVA
    Re: Snub Mount Questions
    Snub mounts are really easy to install you do not have to touch the front bumper at all. It shouldn't take you any more than a 1/2 hour to do. Really easy.
    Senior Member Two Rings rings65's Avatar
    Jan 14 2008
    '06 A4 S-Line
    Wheaton/Winfield, IL
    Yep - piece of cake and no bumper removal required.
    May 12 2008
    Orlando
    Ok good! That is awesome guys! Thank you for the quick response ; )
    Senior Member Three Rings rocketheavy's Avatar
    Mar 21 2008
    A4, Explorer, YZ250
    Connecticut
    install takes about ten min. jack up the front of your car on jack stands. take off your belly pan and look up at the snub mount that is bolted to the engine. Its three allen head bolts. remove the mount, put the OEM snub mount in a vise and pull it off. Install your new one in place of the old one, I did a light coat of anti-seize as lube. reinstall your new snub mount. You will have to loosen the 3 nuts on the "O" ring on the front bumper that the snub fits into. Snug up the nuts on the O ring, put the car back on the floor, start and let the car idle for a min. Now tighten the nuts for the O ring bracket and your good to go. It may take a few adjustments to get the O ring bracket centered but youll notice a huge difference. I hope this helps a little
    03' 1.8T Tiptronic
    Baileys DV, 15% tints
    Ziza yellow Fogs
    Blacked out grills/trim, De Badged
    Apikol snub mount, clear corner mod
    A6 engine mounts
    May 12 2008
    Orlando
    Quote Originally Posted by rocketheavy View Post
    Perfect!
