Results 1 to 18 of 18
    Dec 08 2007
    Whittier, Ca
    Clicking Noise - Serpentine Belt?
    i did a TB job a couple of weeks ago, and i began noticing a light 'click' noise when the car is idling. it sounds like its coming from the serpentine belt area. More specifically, it looks like the belt tensioner pulsates in sync with the click...
    is it safe to run the motor for a minute or so w/o the serpentine belt to try and diagnose the noise?
    any recommendations?
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    Re: Clicking Noise - Serpentine Belt?
    make sure the timing belt cover isnt hitting it.
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    You can disconnect the belt to see if the noise goes away. You will get a couple of lights on the dash as the alternator isn't being activated.
    I have a loud clicking/popping noise and it turned out to be a seized A/C pulley.
    Veteran Member Three Rings cjonesgo's Avatar
    May 22 2007
    02 A4 Avant 1.8t qm, '74 Vespa
    oakland ca
    hmmmm I have a clicking also. It was clicking before my TB job so I figured it was normal, now you have me worried... definitely going to keep up with this thread! I thought it was louder after the TB, but decided it was all in my head.
    [CENTER]02 A4 Avant 1.8tqm Dolphin Gray
    Blackout Grills | S4 Bi-Xenons | 3.0 Brakes | RS4 Rear Swaybar | Bilstein Sport Shocks
    K04 | REVO | TT225 Injectors | Apikol SMIC | 034 HFC |
    Established Member Two Rings B7Lee's Avatar
    Jun 01 2008
    B8.5 S4 - previously B7 S4
    Boston, MA
    I definitely have a slight clicking as well. I thought it was normal as it occurs after the car is warmed up and then stops after about 6 clicks. I'll keep up on this thread too...
    05.5 Quartz Gray S4- MaD StUfF yoooO.
    Deactivated Three Rings
    Oct 07 2008
    Santo Domingo, Dom. Rep.
    Have the same problem after i did my TB. Mechanic says it's nothing to worry about. Will definitely keep an eye on this thread!!!
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    I've had a clicking from the serp tensioner or roller for about 5,000 miles. Definitely the best option is remove the serp belt and run the car to be positive that the noise is coming from the serp and not the TB... then wait for it to get a lot worse before you fix it. Once it gets horrible you can take off the belt and move the various pulleys/rollers with your hands and feel which one is bad. If you replace too proactively sometimes you replace the wrong parts at a great expense and hassle.
    If the serp belt breaks it means nothing except a tow to your house or shop. Yes it's safe to run the car with the belt off, but without the alternator generating power it will drain the battery pretty quickly.
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I have a brand new serpentine belt tensioner if anyone needs it. Still in box, never used.
    -Doug
    Dec 08 2007
    Whittier, Ca
    Sounds like this porblem is common. i wasn't going to make too big of a deal out of it, but after reading Dougyfresh's thread on improper torque of the pully,(http://www.audizine.com/forum/showth...ht=timing+belt) - i became concerned...
    off the top of anyone's head: is there room to remove the serp belt w/o removeing the lock carrier, or do i have to prepare myself for another day of F bombs?
    Apr 20 2007
    Lander, Wyoming
    Yes there is room to get the belt off without removing anything else but it's a tight fit. Just make sure you know how to route it when you put it back on the car. Maybe have a pic of the routing handy for reinstallation.
    Jon
    go > show
    Ich liebe mein Audi
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by lookaught View Post
    I've done it while my car was strapped down to a chassis dyno. I've also removed the serpentine belt tensioner with the front end on. It takes patience but it can be done. Make sure the engine is cool. You'll burn your hand on that upper radiator hose.
    Quote Originally Posted by drew62 View Post
    If the crank pulley is wobbling while the car is idling then those four bolts are loose. With the car off you can reach up from underneath and put your fingers on the bolts to see if they are 1)there and 2) hand tight. You'll need the front end off to remove that pulley. Its too much of a bear otherwise.
    -Doug
    Veteran Member Three Rings festerfm's Avatar
    Feb 07 2008
    just the a4
    northeast pa
    i just fixed my issue w/ the tapping sound.. only prob was it fixed itself.. thought i had a bad mount since it would only make the sound off idle.. turned out my crank pulley had loose bolts. i thought the pulley itself was bad so i didnt do anything til the day the final bolt head snapped off.. after i pulled over and waited for the pulley to catch up w/ me on the road, i decided that the car had been mod free for too long and wanted a new power pulley since the neuspeed pulley is cheaper than an oem from dealer. 3 bolts had back themselves out adn the last one just snapped off.
    here's what ya do.. look at the pulley at idle.. see if it is wobbling.. if not, also wait for engine to cool and reach up underneith and check if all 4 bolts are there. if need be, take off the belt and see if you can wobble the pulley. i originally thought it was either a mount or the tentioner since the tensioner was moving to the tapping sound.. then i looked at the pulley and saw it wobbling like an irish ST. pattys day parade
    i changed mine while only removing the front mount w/ the snub.. it was a pia, but doable. also, get new bolts from the dealer.. i tried doing mine w/ bolts from autozone and there's not enough room to get a socket between the center hub and the bolt.. you WILL be throwing F bombs all over if you dont use the oem hex bolts.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by festerfm View Post
    Are you serious? This sounds all too much like last week for me. Except my pulley stayed on the motor.
    Did you check the pulley that fell off. Is it damaged? I hope it does not look like mine did. If so, remove it and put a new one on. You'll just damage it further for it won't stay on properly with ovalized holes. You also run the risk of damaging the holes within the timing belt pulley on the crank.
    -Doug
    Feb 07 2008
    just the a4
    northeast pa
    mine looked exactly like his did... except i also had marks from it rolling down the fuckin highway at 60mph.. trust me.. you WANT to catch it before it falls off.. if it does get bad enough, it's an excuse to get a neuspeed pulley... they go for about $130-160 w/ new belt whereas dealer wants $190 for a new pulley
    Senior Member Three Rings riot5alex's Avatar
    Jan 25 2008
    03 3.0QM
    Illvine, CA
    Quote Originally Posted by [email protected] View Post
    yuupp.. exactly what happened to me.. also i got a funny smell.. like something was burning i got the light that my alternator was out and i lost power steering.
    cost like 450 to change it. and this was all on new years eve
    Feb 07 2008
    just the a4
    northeast pa
    Quote Originally Posted by riot5alex View Post
    ouch!!! glad i had the time of to DIY
    Dec 03 2005
    2 pedals 1FG
    connecticut
    You can get the OEM steel pulley for around $130-150
    -Doug
    Feb 07 2008
    just the a4
    northeast pa
    price i got was dealer..
