Results 1 to 13 of 13
    Mar 22 2007
    Long Island
    squeak on startup - advice?
    the past two winters i've experienced a loud squeaky noise on cold startup. it's coming from the front of the motor and sounds like its accessory belt related, but who knows i've heard stories of timing belt issues too. my timing belt/waterpump was replaced 35k miles ago fwiw. the squeak goes away after warming up, and its only evident on cold starts in the winter. i bought a new accessory belt but i will be pulling the motor soon to go stage 3 so i dont want to only replace the belt and not fix the issue. i'm guessing it's the accessory belt tensioner, but i was wondering what u guys thought. its kind of hard to get a stethoscope in there to really be sure. advice? thx.
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: squeak on startup - advice?
    Could be a belt tensioner, could be the steering pump. My steering pump likes to make noises in the winter too..
    08 S4- Stock SOLD
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    Quote Originally Posted by mholme View Post
    mine as well, check the fluid level, it dosen't take much to over/under fill the res, for it,
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by S4_NE View Post
    No it's full..It squeals when cold regardless. It's a rebuilt unit as well.
    08 S4- Stock SOLD
    Established Member Two Rings RenegadeEngr's Avatar
    Jun 15 2008
    San Francisco
    That has happened to me when I start up the vehicle the past week when it is like -15F. I would imagine if it is happening when it is really cold it is thermal contraction thing.
    2001:Silver:S4:DarIntake:ABT Chip
    Mechanical/Fluids Engineer
    Sep 05 2007
    Wood Dale, IL/Schaumburg, IL
    A bad or malfunctioning steering pump wouldn't make a squeaking noise, it would be more of a whine. You either have a stretched belt (just an old serpentine/accessory belt) or a bad tensioner. However, I really think you have crappy belts because if a tensioner took a shit, the squeal wouldn't go away, it would be constant. I would replace the serpentine/accessory belts and go from there.
    -Mike
    Current: 2009 Black Ford Mustang GT - Stock
    Sold: 2000 Audi S4 Quattro Sedan - Light Silver - Stock as hell.
    Sold: 2003 SVT Cobra Mustang - Sonic Blue - Not even CLOSE to stock.
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by SonicBlur View Post
    -Mike
    Without actually hearing the "squeaky" sound he's talking about, I wouldn't rule anything out. One man's squeak is another man's squeal is another man's whine..
    08 S4- Stock SOLD
    Sep 05 2007
    True...I'm just speculating, just trying to get the gears turning in his brain as to what it could be.
    -Mike
    Veteran Member Four Rings haus4's Avatar
    Apr 27 2008
    silver s4
    LI
    Chris,
    I had a quick squeak upon start up too, but when it was warm out. It was the accessory belt. I sprayed a little WD-40 on the belt, and tensioner just to see if I could get rid of it and it worked for a few days. Then I did the t-belt and everything associated and it went away for good.
    Mar 22 2007
    Long Island
    im hopin its just the belt, i dont want to have to rip off the front end again after doin a motor pull lol.. def not a p/s pump whine, its belt/pulley/tensioner related.. was just lookin to hear from people who experienced similar circumstances(cold weather, fine after warmup, etc) i will try sprayin some belt dressing on it to start the process of elimination.. thx fellas
    Veteran Member Four Rings s2the4's Avatar
    Nov 02 2006
    01 Stage 3 S4 Silvaro, 01 S4 Avant Nogaro
    Western Mass
    Quote Originally Posted by S4444 View Post
    I am having the same issue. My squeak is only at start up and to me it sounds as if the belt slightly slips because it is cold. It has been around -15F these parts, at this point if it isn't stopping you from driving the car I wouldn't worry. Especially because it seems that stage 3 is in the near future and it will be much more simple with the front nose off you can check to see if the tensioner is fu-bared.
    |MRC-Tuned Stage 3| | RS4 K04 Turbos | | RS4 Y-Pipe | | RS4 Airbox | | RS4 Fuel Pump | | 60lb Siemens injectors | | ER SMIC | | APR Bi-Pipe | | All JHM Goodies | Vogtland GT | | Porsche 993 TT Brakes | | 034 Motor & Trans Mounts|
    ...For now
    417whp @ KTR Ayer, MA 110 octane with open dumps
    clicky
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    I have the same issue. it's just the Accessory belt squeaking due to the cold. nothing to worry about.
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Quote Originally Posted by haus4 View Post
    Chris,
    That could have been very bad. Do not spray WD-40 on your belts. That is wrong on so many levels.
    To the OP it probably is your accessory belt. As is gets old it gets dry and less flexible and is prone to slippage. When it's cold the rubber is harder and thus less grippy and will squeak. Your timing belt is a toothed belt and cannot slip. When something goes wrong with your timing belt it does so in a major way.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
