    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    Headlights are stuck pointing at the ground, I need suggestions
    2000 S4 has the headlights pointing at the ground... I've never encountered this before. After we swapped the left rear wheel bearing and put it all back together they point really far down... Im guessing this has to do with the auto leveling sensor that was disconnected to remove the upright.
    Any suggestions for how to correct this with VAGCOM or otherwise?
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Re: Headlights are stuck pointing at the ground, I need suggestions
    Wrong section? You have a B6, correct?
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
    Apr 20 2007
    Lander, Wyoming
    I do but Im not referring to my own car, it belongs to my brother.
    Jon
    go > show
    Ich liebe mein Audi
    Veteran Member Four Rings CONTROL ONE's Avatar
    Sep 19 2008
    2014 BMW M235i 6MT, 2010 Audi S4 6MT
    Toronto, Canada
    I believe this is what you are looking for:
    Xenon Headlamp Adjustment
    Updated 03 Oct. 2007
    Ross-Tech is not responsible for any damage or problems that may result from following these instructions. They are to be used at your own risk. As always, you should refer to a Factory Repair Manual for your vehicle!
    This procedure applies only to older Xenon systems that use KW-1281. Procedures for specific vehicles, including newer cars that use KWP-2000 or CAN systems can be found in the Ross-Tech wiki.
    This procedure details how to perform a Xenon Headlamp Adjustment on many VW/Audi vehicles equipped with Xenons (HID's). This procedure cycles the motorized headlamp adjusters to their center position so that the beams can be adjusted. This does NOT align the headlamps by itself. You still need to manually adjust the headlamps via the adjusting screws as referenced against a suitable aiming target.
    If this procedure is only partially performed, there may be a DTC stored in the Xenon Range memory indicating "Headlights not adjusted". To clear this, you need to complete the entire procedure.
    There are certain test conditions that must be met before doing this procedure:
    Vehicle must be parked on level ground and "settled" on its suspension
    Parking brake should be OFF
    Ignition should be in the "On" position
    Headlamps should be "Off"
    Procedure for Aligning Xenon Headlamps:
    [Select]
    [55 - Xenon Range] (For some newer vehicles, use [29 - Left Light] instead )
    [Basic Settings - 04]
    Group 001
    [Go!]
    Wait at least 20 seconds for the headlamp motors to move. The headlamps are now in their adjustment position. Turn on headlights. Adjust them via their manual adjusting screws as referenced against a suitable aiming target.
    Scroll up to Group 002. The Xenon Range controller has now learned this position as its Home position.
    Click the [Done, Go Back] button and you're all set.
    Note: There have been reports of lowered vehicles displaying an error message in either Basic Settings group 001 or 002. If the vehicle height sensor(s) are bottomed out, it may be necessary to bend the sensor bracket to allow normal adjustment to occur. Also, check to make sure that the sensor arms do not have their pivots facing the wrong direction as shown in this thread: http://forums.vwvortex.com/zerothread?id=2383036
    Apr 20 2007
    Lander, Wyoming
    Excellent info, thanks!
    Jon
    go > show
    Ich liebe mein Audi
