Originally Posted by
Wanted
For those who are leaking and you're not seeing anything on the ground or on your splash guard - you may need to look at the boots over the tie rods to see if it's collecting there. If so, you may have a pump problem which isn't too bad of deal. It's a 4 out of 10 banana job if you're handy. Worst case scenario is that you are having steering rack issues, but while it does happen - it's not very common.
Will95 - the power steering fluid needs to be a "mineral based" power steering fluid and can be purchased directly from your VW/Audi dealer (anywhere from $18-24 per liter) or at Napa for around $17 for alot more product. O'Rielly's and Autozone do not carry the mineral based product.
Be aware that your power steering pump is as succeptible to damage by being overfilled as it is to being underfilled. This fluid is a cold vs operating temperature level just like an auto tran. In really cold weather based on a bulletin that was posted here some time ago from Audi you can overfill as much as 10mm on the dipstick to alleviate any howling from the pump.
I had the same issue a few backs. I had a chronic PS leak, and could not really source where the leak was coming from. Turned out my PS rack failed on the passenger side, and the fluid was just pooling up in the dust cover. Sadly I had to get a new rack, which is way too pricey, but that is the nature of the beast.
Be careful, as stated above, not to let your res run dry or over flow it. You don't want your pump to fail on top of the rack, if that is the case. Both parts are rather expensive. Check the tie rod ends, check the clamps on the pump lines, and check all your dust boots for any pooling. I used the Audi OEM mineral fluid or the Pentosin, Just remember that once you find and fix the leak, that you will ideally need to flush your old fluid it and refill it with the new fluid you plan on using. Good luck.
