Results 1 to 40 of 43
    Veteran Member Three Rings dextrek's Avatar
    Aug 26 2008
    B7 S4
    Detroit
    APR stage 1+ @ 24 PSI?????
    Recently, temperature in Detroit has been dipping down anywhere between 10 degrees F to 0 degrees F. And I notice that my boost is hitting between 22 PSI to 24 PSI when WOT. I just thought it was boosting more due to really cold conditions and my ecu was adjusting to the cold weather, but the other night my CEL came on while boosting around 24 PSI. I restart the car and it was boosting normal but the CEL stayed on. So I got worried and stopped boosting hard...just in case. Any inputs why this is happening or anybody experience this with stage 1+? Also, can I damage my internals if I boost that high with K03?
    -Ben-
    B7 S4 Dolphine Grey
    B6 A4 USP Moro Blue *Sold*
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Re: APR stage 1+ @ 24 PSI?????
    No, but check out that CEL.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Buncha motorcycles
    Memphis, TN
    i doubt you can hurt your internals on 1+ lol... mine regularly hits 23psi.. but it doesnt hold it, it just peaks... CEL is probably not related.. vag it and see
    APR Stage 2/AWE Intake
    Veteran Member Three Rings festerfm's Avatar
    Feb 07 2008
    just the a4
    northeast pa
    when i got my 1+ i put the gauge in afterwards and got nervous as hell since it would spike at like 26psi for a split second but then back down to 21-22.... never had a cel tho.. it's not abnormal for me to see 22-23psi now.. i just enjoy it for the brief moment that it holds.. :-D
    Veteran Member Four Rings Sablea4's Avatar
    2018 Suburban, Husqvarna riding mower :P
    Charlotte, NC
    mine boosts to 25 sometimes. it could be the gauge. but 50k miles from me with no problems related to boost or internals. hope that helps
    Current: 2017 Audi Q7 Premium Plus. Carrara White with Nougat Brown interior. APR Stage 2, RocEuro intake, BMC filter
    Sold: 2005 Audi A4 Ultrasport Avant red with manual transmission USP CLUB MEMBER #6
    Sold: 2004 VW R32 Deep Blue Pearl
    Sold: 2010 VW CC Shadow Blue Metallic manual transmission
    Oct 22 2005
    Reppin the Mitten.
    What gauges are all of you using...Could be the gauge being rather innaccurate like my stupid AWE one it seems.
    Veteran Member Four Rings gotboost's Avatar
    Nov 04 2007
    Minnesota
    The most mine ever spikes to is 21psi
    Current:
    2002 A4 Avant - Eibach Pro Dampers | Rev Motoring Springs | 034 Motor Mounts | 710N DV | Apikol Snub Mount | 18" S4 Peeler's
    2001 Imola S4 Satge 2+
    2003 A4 GT2871r 303 AWHP 291 AWTQ
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    I wouldnt be surprised if the code you threw was a lean code.
    But what do I know....check that CEL
    -Sami-
    Veteran Member Four Rings a4wd's Avatar
    Jul 27 2004
    B6 1.8TQM 5speeeeeeeed
    Bay Area 925
    misfire?
    another stereotypical Audi
    Veteran Member Four Rings chadb2434's Avatar
    Oct 07 2008
    East Texas
    My GIAC 1+ usually spikes right at 21 and holds 20 or 19...
    I think it might be your gauge...or mine
    02 A4 3.0Q6MT
    -chad
    Veteran Member Four Rings BNZ TOY's Avatar
    Oct 29 2006
    1G FX35, 03 R6, B6 A4 MT6
    Vancouver
    mine still spikes 17 and holds 15, i suck.
    RPI says 14.5 to 15.5 is the norm for APR 1+, I dunno....
    Another silver B6
    Go/Stop: K04-015 ~ Intake/TIP ~ Forge Splitter ~ Neuspeed turboback ~ B&M SS ~ H&R Sport w Bilsteins ~ S4 Sways ~ Eurocode FMIC ~ 245 Rotors/18z ~ FX300 240mm LWFW ~ Snow Meth Inj ~ EURODYNE tune
    Flair: USP Front ~ Cupra R ~ S4 Trunklip ~ Euro Roof Lip ~ VMR v710 235/19/35 ~ S4 doorblades ~ B7 rear valance ~ LED fogs ~ B7 DTM skirts ~ Euro RS4 Steering Wheel ~ S4 Recaros
    Jul 27 2004
    Bay Area 925
    ^^ you should get that re checked... I get 24psi peak as well on my Revo 1+
    Charlotte, NC
    im running a blitz digital turbo timer boost gauge combo.
    Veteran Member Three Rings kwik_shift's Avatar
    Aug 28 2008
    2020 SQ5
    Lake County, IL
    Autometer gauge hits 22psi and holds 19-20psi
    Aug 26 2008
    B7 S4
    Detroit
    The weather got little warmer nowadays so I went WOT in 5th gear, and the car goes into limp mod, but I don't get a CEL. This happens almost evertime so I just use my APR code delete to get back to normal.
    So I checked the CEL and it came out as P0234: Boost Pressure Regulation: Limit Exceeded (Overboost Condition). So I did some research on this and found that there could be several reasons for this.
    1. Hoses incorrect connected, disconnected, blocked or leaking.
    2. Malfunction N75
    3. PCV Valve
    4. Fuel rail pressure
    5. Turbo itself...it is probably a stuck actuator on the turbo. Or the vaines inside the turbo are clogged up.
    I am going to check for the leaks, the N75, and the PCV, but I am sorta worried that it might be my turbo. It's stock so it's not a huge deal, but I was planning on selling the car. Either way, any input will be appreciated. TIA.
    -Ben-
    B7 S4 Dolphine Grey
    Veteran Member Three Rings whiteUSPflow's Avatar
    Feb 22 2008
    2004 USP 1.8tQ, 2003 RS6
    Richmond, VA
    whats up with the APR code delete? is that what they call V-tune?
    USP CLUB MEMBER #97
    APR tuned K04-Carbonio-Forge-Podi-Stasis-034 Motorsport-RAI motorsport
    Unitronic tuned RS6
    Aug 26 2008
    B7 S4
    Detroit
    No, I think they call it Fault Code Erase. It's just a way to get rid of CEL.
    -Ben-
    B7 S4 Dolphine Grey
    Veteran Member Four Rings coowhip's Avatar
    May 11 2008
    Columbus, OH
    sorry to thread jack, but should new CP's and plugs be put in before or after the reflash to 1+ on APR.
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    Holding 21-22psi on a Stage 1+??? I didn't know it was that high. What rpm range are you seeing this pressure, and when does it fall off?
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Veteran Member Four Rings mrbacardi35's Avatar
    Sep 18 2006
    Fresno/Los Angeles, CA
    Quote Originally Posted by dextrek View Post
    check your coils.
    Aug 26 2008
    B7 S4
    Detroit
    Quote Originally Posted by lookaught View Post
    It hits 22 to 24psi around 3800 rpm till 4300.
    How do I check if the Coilpack is bad or not? Any way to tell they are bad?
    -Ben-
    B7 S4 Dolphine Grey
    Oct 22 2005
    Reppin the Mitten.
    ^ call me 810 three three three seven three three three and I'll walk you through replacing the coils. Its easy as PIE. Doubt anything is wrong tho if u can still drive with 20 psi plus.
    Senior Member Two Rings GermanAudi's Avatar
    Jun 01 2008
    2003 Audi A4 1.8T Multitronic
    San Diego, CA
    Quote Originally Posted by chadb2434 View Post
    How are you stage 1+ guys running 20+ psi boost? I peak at 15 psi with stage 1. Do injectors make that big a difference?
    2003 1.8T Multitronic CVT, Canvas Beige Metallic
    GIAC Stage 1 || 710N TT Diverter Valve || 6000K Xenon HIDs || VMR Vent Boost Gauge || Eibach Pro/Bilstein Sport Suspension
    Oct 07 2008
    East Texas
    yessir!
    02 A4 3.0Q6MT
    -chad
    Jul 27 2004
    Bay Area 925
    going from 1 to 1+ is a pretty big improvement.
    FYI, changing my coilpacks, plugs, fixing the coolant leak and the boost leak makes me love my car all over again
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Just got my injectors and 1+ reflash today - it definitely makes a difference! Right now I'm holding at 18-19! We'll see how it stays after a few days of the ECU adapting...
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Veteran Member Four Rings jursch2211's Avatar
    Feb 05 2008
    Illinois
    Quote Originally Posted by coowhip View Post
    I don't think its necessary but when I was having it done, I put new coils and spark plugs in before the flash.
    || APR | BW K04-015 | ER FMIC | OEM S4/RS4/R8 Parts | '10 RNS-E | Hotchkis | Adam's Rotors | Podi | OCarbon | Euro Headlights | Euro Color DIS | Euro MKII TT MFSW | Euro Trunk | BBS | Vogtland Coilovers ||
    Feb 07 2008
    just the a4
    northeast pa
    of course the injectors make that big of a difference.... they wouldnt be expensive if they didnt give a big improvement
    <--------yes, i used my audi to drag my deer out of the woods. it was heavy, i was cold, car had heat, much less work, and frankly, it was far. the deer was big, i am not, just seemed like the right thing to do. if it werent for the apr2+ i may not have been able to pull that monstrosity out of the woods w/out a helicoptor. i cant afford a helicoptor, i have a hard enough time affording my audi. all this being said, yes. that is an apr2+ awd audi pulling a deer out of the woods.
    Oct 22 2005
    Reppin the Mitten.
    ^^did you ever race that gti or vr6...?
    Jun 01 2008
    San Diego, CA
    Quote Originally Posted by festerfm View Post
    But how do bigger injectors give you more boost?
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by GermanAudi View Post
    The injectors don't. The software tuning that goes with the bigger injectors changes the boost.
    Feb 07 2008
    just the a4
    northeast pa
    your bigger injectors will flow more fuel than u'r stock injecectors in the same amount of time as your stock injectors. more boost requires more fuel. basically, your ecu knows how much fuel you need for a certain amount of boost, and all you have to do is tell your ecu what size injectors you have and it adjusts accordingly.
    now that is straight from my pretend book called "turbos for dummies". in reality, it's much more complex, but that is the long and short of it..
    May 03 2008
    Orlando
    I don't know that I agree with the logic that if something is expensive it must give a big improvement, but since you dragged a freakin' deer out of the woods with your Audi I won't fight you on it!
    Kevin W.
    Feb 07 2008
    just the a4
    northeast pa
    i swear to you that deer was huge... i got almost 60 lbs of ring sausage out of her and still got some burger, steaks, chops, and t-loin... she was huge... and in a nutshell, my previous post was a bit stretched. maybe i should ammend it and say when it comes to our audis, you can only have 2 of three things... the 3 things are easy, cheap, and effective.. if it's effective and cheap, it's not easy. if it's effective and easy, it's not cheap, and if it's easy and cheap, it's not effective.. and again, that only applies for 99.9% of things... there might be an exception.. i havent found it yet
    May 03 2008
    Orlando
    now THAT is an awesome formula. Applies to pretty much everything I've done to my car.
    Kevin W.
    Apr 05 2009
    1984 Audi 4000S Quattro, 1989 Toyota MR2 SC, 1960 Alfa Spider
    SF BayArea
    I am very interested in the APR stage 1+ set up. Has anyone run this for a long time to see how the engine holds up? Anyone here running the Stage 1+ alone without an exhaust or intercooler upgrade? I don't mind spending a few bucks on the TT injectors if it makes a big difference in performance without trashing the engine. But I don't want to then find out I need $2500 more mods to go along with it!
    Oct 22 2005
    Reppin the Mitten.
    Quote Originally Posted by onlyaudis View Post
    I ran Apr 1 for about 30k miles, and Apr 1+ for about 65k miles so total of 95k miles on Apr. No problems. I did have a aftermarket exhaust, but not a upgrade intercooler. You will get heat soaked, but thats ok.
    Apr 05 2009
    SF BayArea
    I guess without the exhaust upgrade, you will not get the top end power increases. How about torque at lower RPM's? Would the stock exhaust still do fine with stage 1+ in that area? I have got to hold the line on my mod budget somewhere. Plus, this is a street only car, and I really would like to avoid a louder exhaust. I already have a few classic sports cars if i am in the mood for noise! My old Abarth at high rpm's sounds like a formula 1 car.
    Feb 07 2008
    just the a4
    northeast pa
    kinda tough for me to help here since i had the apr exhaust when i bought the car, but i'm a year and a half w/ apr.. had stage1 for 8 months and 1+ for 8 months more.. only thing i've had on for that time was the exhaust and a boost gauge. still holding up strong even at 116000 miles.
    Veteran Member Four Rings LampyB's Avatar
    Apr 25 2007
    MA
    i boost at 22-24psi with my Podi. the original podi i had boosted at 22psi, but once i swapped it out with the upgraded gauge it goes way higher, and the needle buzzes like crazy and fluctuates a lot too. sometimes when i turn the car off the gauge won't fully go back to zero, it'll stick at like -2inHG until i flick it. not the greatest...
    Custom Trunk Badges For Sale!
    | 2004 A4 USP 1.8TQ | 6SPD | GIAC 1+ | APIKOL | HYPERBOOST | FORGE TIP | NGK | 20% TINT | VMR | OFE SS | PODI | N249 Delete |
