Results 1 to 11 of 11
    Registered Member Two Rings
    Jun 04 2008
    MA
    Question Other options for motor swap in a A4 B5 2.8 shell
    My son and I might be getting our hands on a A4 2.8 5-speed shell. Motor was pulled but thats it. I myself have an S but we were looking to see if there are any other motor swap options that we could drop in the shell other then the 2.8. I tried to do a search to see if anyone has swapped the 2.7t or even the 1.8t into one of these and what was involved. Was wondering if a motor, ecu and harness were the only things needed along with mounts im guessing.
    I'm really looking to hear from you experts on this chassis and was thinking of doing this as a project with my son, esp. since the shell is really cheap and in good condition other then not having a heart. Dont really want to grab it to put another 2.8 in it.
    Veteran Member Four Rings haus4's Avatar
    Apr 27 2008
    silver s4
    LI
    Re: Other options for motor swap in a A4 B5 2.8 shell
    Well as you know, the 2.7 and the 1.8 were both stock options on the b5. I would assume you need a different sub frame depending on which engine your looking to drop in as well as tranny. There are others that have done this and hopefully will chime in.
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    if u go 1.8t your gonna need the 1.8t sub frame but if your gonna add a 2.7 then u can use the 2.8 sub frame
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Active Member Four Rings DxC's Avatar
    Nov 16 2006
    Boston
    2.7t is boring, put an ls1 in there :)
    1999 Black A4 Avant
    2000 Nogaro S4 Stage 3
    2001 Nogaro S4 Stage 3
    2000 Black S4 - under construction Stage 5?
    2001.5 Santorin S4 Stage 3
    2001 Black S4 - parting out/scrap
    2001 Black Burnt S4 - shell gone, drivetrain remains
    Jun 04 2008
    MA
    Quote Originally Posted by AMC View Post
    Thanks AMC, off the top of your head what other components would need to be swapped over?
    Veteran Member Four Rings Kruat's Avatar
    Nov 10 2004
    01 S4, 03 RS6, 15 A8L, 16 PSD F350
    Longview, WA
    Do a VR turbo...
    --Mike--
    01 Casa S4
    03 Mugello RS6
    15 Moonlight A8L TDI
    01 Aviator TT (sold)
    99.5 Santorin A4 (sold)
    04 Cobalt Allroad (sold)
    Jun 04 2008
    MA
    Quote Originally Posted by DxC View Post
    Thanks Dave but this is going to be for my son as a project for us. LS1 is not an option, lol!
    Jun 04 2008
    MA
    Quote Originally Posted by Kruat View Post
    Do a VR turbo...
    Any certain reason you would go with the VR6 Turbo'd?
    Senior Member Three Rings lowered97a4's Avatar
    Mar 08 2007
    08 turbo busa 09 nissan Gtr
    ct
    i think u need the 2.7 s4 subframe i think something with trans mounts are different
    2001 s4 stage 3
    Sanitorin Blue
    10secs4 tune
    meth injection
    JHM/AMC trans rebuild
    03 Rs6
    Wagner intercoolers carbon fiber shrouds
    Ecu/Tcu tune
    Cats Removed
    Nov 18 2008
    2018 Passat R 1999 A4 2.7t stg 3+ 2019 Tiguan
    Chicago
    Will be putting in the 2.7t in the next few weeks, my 2.8 is out, will post progress pics in the next few weeks.
    Go BIG or GO HOME!
    Mar 01 2007
    2003 996TT, B6 A4 2.7t
    Montreal
    Installing a 1.8t in the place of the 2.8, invloves replacing the front rad support, as the 1.8t has a different lower section with the boost pressure pipe running through it. You dont need to change the subframe, in fact, you can use the 2.8 transmission. You will also need the bracket that supports the intercooler, and the power steering pressure hose from pump to rack. Also, you need a 1.8t radiator, as the inlet/outlets are positioned differently.
