    Registered Member Two Rings
    Jan 08 2009
    AUDI B6 DG A4 3.0 Quattro
    SB Socal
    ECL due to Timing Belt kit?
    While driving back to home from Los Angeles, suddenly Engine Check Light came up from nowhere. I pulled her over and checked a couple of things, but nothing abnormal was found to my sight. If Timing belt or Tensioner was worn out, Does ECL appear on the trip board to warn?
    Lately, I thought of replacing timing belt kit including Tensioner(it makes a metallic sound from the front end according to the dealership). SA said those are cracked and worn too much so that they must be changed immediately. I know the dealership often exxagerate things to scare customers, so I declined. She has 77,000 miles.
    Any help will be appreciated.
    Veteran Member Three Rings ziggituning's Avatar
    Mar 04 2008
    04 B6 1.8T Q 6 spd
    Re: ECL due to Timing Belt kit?
    timing belt and all related tentionners and water pump should be changed when due, yours would be due (in my books anyway), so do not play around, it is like engine russian roulette, if it goes so deos alot of engine internals. You will get no warning signs, no lights, just silence once the engine implodes!
    Good luck!
    PARTS FOR SALE: LW Crank Pulley, OEM injectors, ABT rep grill, OEM Intercooler, PM me.
    For your OEM HID D1S/D2S/D3S and HID conversion [Headlights/Foglights], and Interior/Exterior LED needs, send me a PM![/SIZE]
    May 24 2007
    Southern California
    intersting. first off, you won't get any lights as stated above. the thing that interests me is the "metallic" sound your engine makes. Is it only at start up or does it continuously make the sound? Sounds like something is just loose or there is metal to metal rubbing (example: heat shield to firewall)
    Kyle
    2.0L Revo GTRS Eliminator
    Jan 08 2009
    SB Socal
    At the very first of start up, it doesn't sound, but it starts to appear in about a minute. Definitely not from the engine, but somewhere around front end. SA said it's because of tensioner. What do you think?
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Do it ASAP, granted you have to pay alot to get it done, but not near as much if it fails.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
