Results 1 to 9 of 9
    Active Member One Ring Mister Low's Avatar
    Dec 25 2008
    B7 2.0TQM S-Line, 00 R6
    KY
    Fuel gauge issue
    Having a problem getting a correct reading on my fuel gauge. I did some searches and couldn't get a good answer for my issue on whether it's the cluster or the fuel sender(s).
    My gauge works accurately from full to 3/4 full. Then when the gauge is at 1/2, there is roughly a 1/4 tank of fuel left in the tank. It reads just below 1/2 when I hit the mileage I would typically fill up at. So I need input on whether this is the cluster or the senders. The gauge has been pretty consistent with the incorrect readings. This is an '02 1.8t
    est. '02
    Veteran Member Four Rings J-jizzle's Avatar
    Aug 28 2007
    Tools, Parts and the GTI beater
    Birmingham Alabama (Tennessee)
    Re: Fuel gauge issue
    My fuel gauge does not read much past the 3/4 of a tank mark. When I get gas it will read up to that point but not any further. Unlike you, the gauge reads accurate after that point. I have like 8k on my new fuel pump which is where the sender is located. I have had the problem about 3k, so I might take the pump back out to make sure all the hoses are clear of the Bobber then go from there.
    Mar 27 2005
    The Cold North
    i have had this issue this past summer. The first time they replaced the fuel sender in the tank in August. It seemed to work interminitly after, but never really accurate. In September they ended up replacing the fuel sender again and also the gauge cluster from the dash. Everything works perfect now.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    CO
    This was a common issue with the B5's, but I'm not sure if Audi changed the fuel sender for the B6's or not. (and if they did, what year did the change occur?) I would check out the fuel sender first.
    Quartz Gray '11 S4 Prestige || Sprint Blue '06 S4 Saloon - Sold || Denim Blue '02 A4 1.8T - Total Loss || Laser Red '98.5 A4 1.8T - Sold
    Dec 25 2008
    KY
    Ok. I'll wait till I get a little lower on gas and I'll take a look at the senders.
    It's been semi-irratic since I posted this. It was around 5/8 full, then I drove 30mi and it went back to 3/4. Sound like a bad sender with that issue or a bad cluster?
    est. '02
    Mar 27 2005
    The Cold North
    Quote Originally Posted by Mister Low View Post
    I hope for your sake it is a bad sender. The new cluster was $$$$ when i had it replaced.
    2020 Chevy AEV ZR2
    Veteran Member Four Rings Jeff's Avatar
    Feb 18 2004
    Los Angeles, CA
    It's not always the cluster... but the sending unit. The unit is located under the rear passenger-side seat, inside the fuel tank in front of the pump. The unit looks like the floatball and arm assembly found inside your toilet. The ball sits on an arm, that floats based on the level of fuel inside the tank. There are tiny contact switches that tell the car what level the ball is floating at that act like a potentiometer, providing variable voltages to the car. These contacts start to deteriorate by sitting in the tank and submerged inside the fuel. I tried fixing and cleaning them in the past, but it was a bigger pain than just buying a new one.
    Dec 25 2008
    KY
    Jeff I sent you a PM.
    I was thinking, with my past VAG experience, that it was a sender. I just need to figure out which sender it could be (a right and left are listed). Tips?
    est. '02
    Feb 18 2004
    Los Angeles, CA
    Replied
