    Jan 13 2009
    Jaguar XK, Galant VR4, Mitsubishi Starion, GMC Beau James, Yamaha 650 Turbo
    Pacific Northwest, USA
    Fuel pump specs please?
    Bit elusive in the search area.
    On the 2.0T engine. What are the Fuel pump specs? GPH and PSI please.
    Just curious why we are stuck with an archaic mechanical unit? Requirements must be way out there from norms?
    Many thanks,
    Vince
    Current = 2007 Jaguar XK
    RIP Brilliant Red 2005.5 A4Q 2.0T, TIP. Premium, Lighting, Shade, Cold weather, and Audio packages.
    Mods: Shift Paddles added, Enkie PF01, Eibach Pro, Koni FSD, H&R 20mm Sway, USP Stainless brake lines, Tint, APR stage 1, K&N, Stern Adjustables.
    MP3 is the McDonnalds equivalent of music. Both have their place, but neither cater to quality.
    Veteran Member Four Rings IceMole's Avatar
    Oct 09 2007
    E46 M3
    PA
    Re: Fuel pump specs please?
    Directly from APRs site
    A low pressure fuel pump (which varies from ~40-95psi) delivers fuel from the gas tank to the engine. Then, in order to spray fuel directly into the combustion chamber, a high-pressure, camshaft-driven pump pressurizes the fuel to upwards of 130bar (almost 1900psi !).
    -Kris
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    I heard that upgrading the pump will wear put the cam lobe it rides on.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Stage 2 Banner Advertiser Four Rings Arin@APR's Avatar
    Aug 23 2008
    Auburn, AL
    Besides from the information on our website, does any of this help?
    I can also point you to some of the patent information I dug up on my own a long while back:
    http://www.arinahnell.com/other/vw/fp/HPFP%20Patent.pdf
    http://www.arinahnell.com/other/vw/f...Patent%202.pdf
    http://www.arinahnell.com/other/vw/f...Patent%203.pdf
    http://www.arinahnell.com/other/vw/f...Patent%204.pdf
    GoAPR.com | Facebook | YouTube | Twitter | Instagram
    Phone: (800) 680-7921 Local Phone: +1 (334) 502-5181 Fax: +1 (334) 502-5180
    Address: APR LLC, 4800 US HWY 280 West, Opelika, AL 36801
    Jan 13 2009
    Appreciated.
    Any chance of a US conversion so I can understand it? 1900 PSI is definitely way up there, but at how many gallons per hour? I don't see a duration rating in those specs Cubic Millimeter per what?
    1900 PSI is pretty simple for A wobble plate pump, but maybe not the delivery volume?
    I dont even know if a WP pump exists for a reasonable price outside the aviation industry, but it would be interesting to research.
    Thanks for the replies
    V
