Results 1 to 7 of 7
Thread: HP before turbo
    Veteran Member Three Rings A4Triple Blk's Avatar
    Jun 10 2008
    Past - 2004 A4 1.8T Quattro 6 Spd
    LI
    HP before turbo
    Around how much horsepower do you guys think can be put out without going BT ? I'm talking everything except the turbo ?
    B8 2011 A4 Premium+ 6 speed
    Used to B6 it
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: HP before turbo
    well, Im probably the closest thing to it.
    I had a 2L, water/meth, 1+ file
    Basically, since the stock turbo sucks, any power adders you do dont really add much. It felt peppier with the 2L, and the W/M helped, but idk overall how mcuh I really added, maybe 20whp
    - Clint
    Veteran Member Three Rings Monkey77's Avatar
    Oct 30 2007
    2005 Audi A4, Tiptronic.
    new jersey
    Re: HP before turbo
    Depends..You can always go the K04 route, FMIC, Bigger Injectors, Exhaust, and a more aggressive file......But the money you will spend on going K04, you can just go BT. Which is why I regret the K04, and am currently looking to go BT. =)
    Everything but BT, you may get anywhere between 230-250 CHP....Just a guesstimate...good luck
    " You can't be lucky all the time, but you can be smart everyday."
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    Re: HP before turbo
    ~185awhp with a 2.0L engine, K04, intercooler and exhaust
    Veteran Member Four Rings osofast10's Avatar
    Dec 26 2004
    02 Audi A4 1.8t
    woodbridge, Va
    Re: HP before turbo
    i think i had the most... with out a turbo upgrade... intake, exhaust, rods, fmic, stage 1+... oh yeah and a 75 shot of nitrous :) i dyno'ed at 175whp without the nitrous... so i'm guessing on the nitrous i was at about 225 to 250whp and my ftlb had to be some crazy high number... lol...
    1996 2.8 Audi A4 -> RIP
    2002 1.8T Audi A4 -> SOLD
    2005 Toyota Prius -> DD
    2010 Acura RDX --> DD
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: HP before turbo
    1.8 or 2.0 with a K03 is still going to make the same power since the turbo can only flow so much air. Only thing you gain is more tq and the power band actually gets smaller since the hp will peak and fall off much sooner in the rpm's. I ran a K04 to break in my 2032cc back in 2003, it was no faster then my stock 1.8 K03 setup that ran 14.29 at 97 and made 200+awhp.
    Jan 10 2007
    VA
    Re: HP before turbo
    everything except a BT...240-260hp/275-300tq at the flywheel. basically the range of a K03-K04 with all supporting mods. with a BT all of those numbers will basically jump to over 300.
    wheel power will be dependent on dyno and drivetrain.
