Hey people, I just wanted to let people know some stuff that may have similar setups so they do know a reference point.
I have been running 16psi since my clutch slips but last night I turned the boost up to 21psi.
I was seeing 12.5 and 12.6:1 air/fuel on my wideband gauge running the 21psi so at 24psi im sure I would have seen like right at 13:1.
My car
2.0 (83mm bore)
AEB head
Schrick 252/260 cams
stock fuel lines
040 fuel pump
630cc injectors
GT3076
Methanol Injection
Im not sure what difference the meth makes but just figured I would share a little info.
I will soon have the bigger feed line and 75# injectors so I should be golden, but this is for you 630cc guys just to add on top of what 034 discovered running the 630s and upgraded fuel line. (they saw 12.5:1 at 25psi)
