Results 1 to 6 of 6
    Veteran Member Four Rings IceMole's Avatar
    Oct 09 2007
    E46 M3
    PA
    Unitronic BT software
    Just a FYI for those who are currently looking at BT options:
    Designed to run a KMD Injectors updated High pressure fuel pump, GT28xx.GT30XX family turbo's, preset at 20-22 PSI on stock n75 with 10lbs WG spring or EBC support
    $950.00
    clicky
    This would be the software for those of you interested in that recently released ATP setup.
    We need to start catching up to the MK5 crowd
    -Kris
    Established Member Two Rings I495 Bandit's Avatar
    Jan 08 2008
    01 St3+VW Jetta/06 A4 S-Line
    NoVA
    Re: Unitronic BT software
    Yeah Unitronic makes a really nice GT series turbo file for our engines. You can read a ton of info on the Unitronic BT file on the VW Vortex 2.0fsi forum. People can learn so much
    more about our engines over there. BTW Revo also makes a BT & K04 file for our engines too.
    Veteran Member Four Rings Vorsprung's Avatar
    Feb 26 2008
    Raptor, FD RX7
    Long_Island/NY
    It's wierd it seems like nobody with a B7 runs Unitronic, yet in the VW scene they're pretty popular, at least from what I've seen.
    -Ian
    May 03 2008
    06' B7A4 20T Non-Sline
    Monterey, CA, 93940
    Quote Originally Posted by I495 Bandit View Post
    Well hopefully revo could run with the atp kit :P
    Veteran Member Four Rings slimmj0k3r's Avatar
    Jul 31 2005
    Arizona
    nobody really runs it because those KMD injectors are poop....but they get the job done
    Jan 08 2008
    NoVA
    Quote Originally Posted by 06B7audiA4 View Post
    Yeah the Revo Bt file would work. Unitronic and Revo both have a Bt file that runs off of the KMD BT injectors which are just oem b7 RS4 injectors and then you need a hpfp upgrage. One guy on the Vortex has been running the Revo BT file and KMD (RS4) injectors with Gt 3071 turbo and is making some ungodly amount of power with the 2.0fsi on pump gas for like a year now with no issues at all.
