Results 1 to 14 of 14
Thread: Mismatch tires?
    Senior Member Two Rings Doc.'s Avatar
    Apr 27 2008
    Ashburn, Va
    Mismatch tires?
    Could it hurt anything? I know Audi drivetrains are very sensitive, and i was wondering if that mattered.
    I got a flat tire today and i didnt notice till the sidewall was pretty worn, so im gonna have to get atleast two new tires. The stock Pirelli's are still good on the rear. The fronts (where i got the flat) have a little worn on the outsides from the previous owner not caring about the tire pressure i guess. So i was thinking about just getting two goodyear tires and stick them on the front or maybe even on the back, and keep the other stock two. Should this be ok?
    Nov 19 2007
    Anonymous
    Re: Mismatch tires?
    I was wondering the same thing today examining the tread on my tires.
    I was at a tire shop last year, and service advisor that helped me out informed me that installing mismatched tires would screw up the drivetrain in my Audi. He also made a comment about how my A4 being quattro could contribute to the problem as well.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Re: Mismatch tires?
    Won't hurt a thing. Just don't mix them side to side. Front to back mix is OK.
    Apr 27 2008
    Ashburn, Va
    Re: Mismatch tires?
    Wouldnt that almost be like staggered wheels?
    And also, i guess i shouldnt keep it on the donut for long? I'll call up my buddy tomorrow and see how fast i can get the tires.
    Dec 28 2006
    Western Maryland
    Re: Mismatch tires?
    Quote Originally Posted by Doc. View Post
    Yes.
    Won't be an issue.
    Apr 27 2008
    Ashburn, Va
    Re: Mismatch tires?
    Yes.
    Won't be an issue.
    Established Member Two Rings Plasticar's Avatar
    Jul 08 2008
    B6 A4Avant, B5.5 Passat 4mot
    West Bloomfield, MI
    Re: Mismatch tires?
    Quote Originally Posted by thecheda View Post
    Of course he advised you this way, his job is to sell tires. The quattro drivetrain will accept the difference from new to worn tires no problem. Even if only one is newer. I agree, though, to have the same tires on the same axle.
    If you are going ot all this trouble, you may want to think about having the 2 good tires removed and reversed so the outside is now on the inside. Usually tires wear the most on the outside due to steering and cornering. Swapping them will even out the wear a bit and may get you an extra rotation worth of wear before they are done for. They may be just a touch noisier until they wear in a bit, but shouldn't be much of a problem. Just a thought.
    Nov 19 2007
    Anonymous
    Re: Mismatch tires?
    Quote Originally Posted by Plasticar View Post
    Same tires on the same axle......
    So are you saying two goodyears in the front, and two contisports in the back okay?
    Veteran Member Three Rings audizz a4's Avatar
    Jan 04 2009
    2002 audi b6 1.8t 5spd DG
    grayslake
    Re: Mismatch tires?
    do not do this!!!!! i had a long discussion over on audiforums, i had a problem with this exact thing xcept i used 2 different types of falken tires the ze512 and ze912s same rating etc... created bad body lift and roll.... bad brakeing this is very bad for your quattro system.. buy the same tires as before or replace all four dont cheap out on that its very important
    Veteran Member Four Rings Overboostin's Avatar
    Mar 15 2007
    New England
    Re: Mismatch tires?
    100% true. Just follow that rule and you'll be fine.
    the homebrew'd s4
    Mar 27 2005
    The Cold North
    Re: Mismatch tires?
    you can mix tread patterns of the same size wheel by putting 2 of each pattern on front and 2 rear.
    i personally wouldn't do it but to each their own. i would just buy 4 new tires, get an alignment and start fresh.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Nov 19 2007
    Anonymous
    Re: Mismatch tires?
    Quote Originally Posted by EBG 18T View Post
    And you and the guy before you, are talking about the quattro system correct?
    Just double checking.....
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    Re: Mismatch tires?
    Actually, it isn't very sensitive. It's a very strong system and it takes a considerable amount of abuse to cause damage to Quattro.
    -Darrick
    Mar 27 2005
    The Cold North
    Re: Mismatch tires?
    well the quattro is actually pretty tollorant system (as long as the tire size is within ~3% of each other) I just prefer to have the same tire on all 4 corners.
    2020 Chevy AEV ZR2
