Results 1 to 10 of 10
Thread: RS4 diff?
    Established Member Two Rings Chb04's Avatar
    Jan 12 2009
    11" B8 Sedan , 07" B7 Avant, 11" Jeep Wrnglr Unlmtd
    USofA
    RS4 diff?
    Ok I know the differences between the A4 and RS4 BUT? With the wheels and suspension is the car sitting lower then a stock A4? Meaning lower suspension springs or what? I want to do some things to my Avant but not looking to spend a ton!
    Jan 12 2009
    USofA
    Re: RS4 diff?
    OK???????????
    Is the suspension on the RS4 lower besides being stiffer?
    Veteran Member Four Rings ataylor's Avatar
    Dec 15 2008
    snowboarding, computer, and mountain-bike parts
    Golden, CO
    Re: RS4 diff?
    yes it is lower than a stock A4, especially the non-sline..
    History: MK3 Jetta 2.0 MT; MK3 GTI VR6-SC; B7 A4 6MT STG2; B8 S4 DSG; B8.5 S4 DSG
    Nov 12 2007
    Grand Junction, CO
    Re: RS4 diff?
    You could not put them on the A4 though, at least not the front springs anyway. They are stiffer in order to compensate for a bigger and heavier engine. I would think that if you put the RS4 springs on an A4, it may actually be higher then the stock non-sline. Which would look terrible.
    Jan 01 2008
    Long Island NY
    Re: RS4 diff?
    RS4 suspension sucks, search the RS4 and C5 RS6 forums. DRC dynamic ride control or Doesn't Repair Correctly
    Veteran Member Four Rings QTC's Avatar
    Sep 16 2006
    2004 B6 A4 1.8t 6MT; 2013 F30 320i 6MT; 99.5 Pathfinder 4x4; Mk7 Golf TDI
    Wynnewood, PA
    Re: RS4 diff?
    Haha I've never heard that acronym before, but I like it.
    OP, RS4 suspension is calibrated for a different car, for several reasons. 1, the V8 is heavier than your engine, so the front of the car will sit higher due to less weight. 2, the Avant carries more weight over the rear axle, so the ride height in the back will not be the same as the sedan. 3, like Auditude mentioned, DRC sucks, and isn't worth transplanting. Pick up a good set of coils (Stasis StreetSports are like $950) and a set of 18" RS4 reps and you'll have the look you want with a much better package performance wise.
    Dahlback | AWE | Milltek | Vogtland | H-Sport | Oettinger | Thule | OEM+
    Veteran Member Four Rings Koby's Avatar
    Aug 05 2008
    Easton, PA
    Re: RS4 diff?
    I thought this thread was going to be about the differential, lol...
    Mar 12 2008
    New York
    Re: RS4 diff?
    LOL me too.....
    Jan 12 2009
    USofA
    Re: RS4 diff?
    Wanted to change the title after I posted but couldn't figure out how so sorry for any confusion! But got way more info than I expected and thanks. I'm not looking to install the stock suspension from a RS4 just wondering about the stock set up and now I have my answer.
    Senior Member Three Rings fromGMCtoAUDI's Avatar
    Feb 03 2008
    '08 audi A4 2.0T
    alexandria, VA
    Re: RS4 diff?
    Quote Originally Posted by QTC View Post
    That's exactly what I did, even the rs4 reps are in 18". I'm also loving the setup looks wise and performance wise.
