Results 1 to 8 of 8
    Jan 07 2009
    winnipeg
    does 2000 A6 2.8 has self leveling system on headlight
    hi guys, just wanna know does 2000 A6 2.8 has self leveling system on headlight? cause when i bought my a6 the adjuster is strip, so I can't adjust it.
    Apr 18 2007
    ny
    Re: does 2000 A6 2.8 has self leveling system on headlight
    does it have xenon's??
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    Jan 07 2009
    winnipeg
    yes
    Apr 18 2007
    ny
    When you start the car and turn the headlights on right away do the headlights cycle up and down? If yes then you do have self leveling headlights, if not than you don't have them. I'm pretty sure you do though.
    SOLD
    Greg
    C5UNION
    Jan 07 2009
    winnipeg
    i do have xenon and it is original, but when i start my car it doesn't move up and down, end up I try to adjust it by myself, the adjuster is strip...
    Jan 18 2009
    95 A6
    Des Moines,Wa
    If you have hid you have sensors only on the left side. if you have vag com check address word 55. basic setting 1, it will state wait then adj. adjust your lights and go to basic setting 2 so the system will learn new pos..
    Jan 07 2009
    winnipeg
    Quote Originally Posted by phit View Post
    ok thank you very much, i have already bought a vag com on ebay tonight
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    A lot of times the screws don't strip. The adjusters actually fall out of the ball socket on the headlight housing from being over adjusted. Its just a matter of taking the headlight apart and popping the housing back into the ball joint.
    Or it could be broken....I have seen it just popped out like 4 times though now.
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
