Results 1 to 7 of 7
    Registered Member Two Rings DBA4_1.8t's Avatar
    Nov 23 2007
    02 A4 1.8t; 03 Mazda Protege 5
    Yet another coolant leak... (w/ big pics)
    Hello everyone,
    My car has been losing coolant ever since I changed the timing belt/thermo/waterpump this summer, and I wasn't able to locate the problem until today. The leak is coming from the thermostat area, and has built up in underneath the intake manifold. I did the install exactly as the DIY on the forum said, and I'm pretty sure everything is torqued correctly, however I am not confident that I flushed/bled the coolant properly. Judging the photos I've included, what do you guys think is the problem?
    The hose coming from my thermostat.
    Underneath the manifold.
    The bleeder screw, but nothing has really built up here.
    The buildup around my fuel injectors.
    Any advice would be great!
    2002 A4 1.8t Quattro Sport
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Re: Yet another coolant leak... (w/ big pics)
    Its leaking from the bleeder and running down. As it sits it starts turning into a crust.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Veteran Member Four Rings Redgoat's Avatar
    Sep 16 2005
    did you use a new crush washer after opening the bleeder?
    -Karl
    NWQuattro - Northwest Audi Club
    USP CLUB MEMBER #8
    BetaAlphaTau member #10
    Nov 23 2007
    I didn't use a new crush washer, actually didn't even think to. What would explain the leak around the hose coming from the top of the thermostat?
    Senior Member Three Rings zbrock06's Avatar
    Oct 15 2006
    '04 USP A4 1.8TQ
    Stamford, CT
    do you need a new washer after opening the bleeder, i replaced my TB and flange and now i ahve a leak and i have no fucking clue where to even look i'm starting to get sick of this car, please help!! my next idea would be the t-stat, i do'nt see how my coolant flange couldn't last only a month. I opened the bleeder but didn't replace the washer.
    USP CLUB MEMBER #94
    Veteran Member Four Rings eurogruppe's Avatar
    Jun 05 2008
    2021 RS6
    Cleveland, OH
    mine was leaking from the bleeder a month ago, took it to the dealership and fixed it for free, as well as refilling my coolant to the proper level.
    21' Audi RS6 | E30 M3 | 996 Turbo | Corrado SLC | IG: @stevedavid993
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Did you check here Other coolant post Its under the intake manifold too.
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
