Results 1 to 10 of 10
    Jul 16 2008
    05 Avant 1.8t Qtip
    Toronto, On
    Exhaust question....need some feedback
    im thinkin about removing the middle resonator so the engine breathes better cause i feel there is a restriction especially when i step on the gas. Just wondering what u guys think and if its a good idea and worth doin. Also if i do it, my shop said it wont be loud at all, just wanna make sure thats the case
    thanks
    Veteran Member Four Rings ApexIt's Avatar
    May 28 2008
    2005 A4
    Re: Exhaust question....need some feedback
    i heard that removing the resonator does make the exhaust sound louder, at least more aggressive.
    Veteran Member Three Rings festerfm's Avatar
    Feb 07 2008
    just the a4
    northeast pa
    want the engine to breath better, pick up a test pipe for like $120 or so from ebay... might get a hint of more noise from u'r exhaust, but it'll make u'r engine breath much much better... plus, lower egt's, it's actually good for u'r engine...
    Jul 16 2008
    05 Avant 1.8t Qtip
    Toronto, On
    so what about the resonator, worth doing it or no?
    Dec 01 2007
    Orange County, NY 10918
    Quote Originally Posted by sergeA4 View Post
    Gonna make it alot louder. Get the TP you'll be happy with it. 034 TP No regrets with it.
    C6A6 3.0t Avant
    @avantneil
    @avantoberfest
    @skiguardusa www.skigaurd.com
    Jan 10 2007
    VA
    removing the resonator will not only make the exhaust note louder, but it will be raspier and drone significantly more. volume may not be too loud (subjectively) but it makes a big difference in the sound of the exhaust.
    it would be better to go with either a test pipe or real cat-back exhaust kit. a high flow cat alone would likely help more (power, temp, spool wise) than cutting the resonater.
    Feb 07 2008
    just the a4
    northeast pa
    there are a bunch of dif companies that make a test pipe for our car... do a search. when it comes down to it, just find a test pipe. it might be a PIA to put in, but it's well worth it. sure it's really easy to just cut out the resonator since its right out in the open and easy to get to, but all you are going to get is some extra noise, but no performance gain.
    Established Member Two Rings ultrasport69022's Avatar
    Aug 01 2008
    So Cal
    i had my resonator removed. there is not too much of a difference just a bit louder and deeper tone. i also felt that the exhaust was a little bit less restricted, i would only do it if u have an extra hundred laying around
    Veteran Member Three Rings Jarim's Avatar
    Nov 28 2008
    N/A
    a friend of mine just got the resonator cut out and replaced with a straight pipe on his jetta for $25
    although he only has one outlet rather than dual exhaust...
    anyone have a clip of the stock exhaust with resonators taken out on a 1.8t, or has done this before with the stock exhaust?
    No need to mention the test pipe and how it will provide... blah... blah blah .....
    B6 A4 1.8t MODS: Custom 3" to dual 2.5" Turboback Exhaust, 034 3" Testpipe, K&N Drop-in, FMIC, Hitachi Coilpacks, 007 Diverter, Neuspeed Snub, RS4 Sway, Custom Interior, Yellow Fogs
    Nov 28 2008
    N/A
    bump
