Results 1 to 6 of 6
    Veteran Member Three Rings s42k5b's Avatar
    May 31 2008
    New York
    No heat @ idle fix
    DO NOT replace your heater core before trying this
    http://www.audizine.com/forum/showthread.php?t=258282
    00' Cactus, GIAC,H&R coilovers,original K03's for the time being..
    Aug 06 2008
    Canadia
    Re: No heat @ idle fix
    I'm pretty sure i have a small air bubble in there, i'm going to do this tonight if i can
    the B5 S4 is like the mafia... there is only one way out!
    Account Terminated Three Rings pzp107's Avatar
    Dec 02 2007
    State College pa
    wheres the bleeder on the block?
    Veteran Member Three Rings GetAwayFromMe's Avatar
    Jan 03 2008
    One million dollars all in pennies
    Iowa
    I have never ever used the bleeder hold on tghe bottom. The one by the power steering pump is what i used.
    When i do water pump or flushes here isd what i do. Slide the heater hose so the hole is exposed crack the bleeder hole and pour coolant into the resrvor. The coolant will start comming from the bleeder hole, once that happens than you shut the bleeder. Start the car and let it idle til it warms up, go in and rev it til 1500rpm until the coolant starts comming out of the heter hose. Once that happens clamp the hose and you are done. Bleed it a few more times after thermostat opend and you are golden. I never had a problem doing it this way or any air in the system.
    Senior Member Three Rings Caddy7's Avatar
    May 26 2008
    Silv -00 S4 Tip & -01 A4 2.8L
    Riverside, CA
    That bleeder hole is on the top of the hose right?
    May 31 2008
    New York
    yes
