Results 1 to 6 of 6
    Active Member One Ring NPalacioM3's Avatar
    Jan 15 2009
    M3, Yukon Denali, VD F2000
    Vienna, VA
    Recommended Battery for A4 Cabrio
    Ok, so my girlfriends A4 Cabrio needs a new battery. If we do not get the factory Audi battery, what battery would you guys recommend for the car? I have done a search and seen many results for the Optima battery but seen several different model numbers. Can anyone tell me specifically which one would fit her car?
    Thanks in advance!
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    Re: Recommended Battery for A4 Cabrio
    Optima Red top 75/35
    Veteran Member Four Rings heateris's Avatar
    Aug 16 2004
    08 A4 2.0TQM6 ~ 08 Highlander Sport
    SE PA
    i got a bosch at pep-boys.
    Jan 15 2009
    Vienna, VA
    Thanks guys, I got the recommended battery from Autozone that has the breather tube outlet. I know that isn't a big deal but my gf was concerned about it so we went that route.
    For the install, man that was a pain in the ass . I cannot believe how tucked in that battery is behind the firewall....crazy. And the stress bar makes it almost impossible to access the bolt on the bracket that secures the battery. Ugh, royal pain. But all done!
    Thanks for all the help.
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    yea i know.....i changed my battery today and that bolt was impossible
    Active Member Two Rings Funkychriscoldm's Avatar
    Oct 28 2008
    03 B6 Silver A/T
    Ogden, UT
    Ya I went with the Bosch too and I took all the connections off and the shroud and saw that bolt down there and was like WTF! Had to get pretty long extension, but right tools makes a easy job!
    Keep it funky!
