Results 1 to 20 of 20
Thread: 1psi wtf?
    Account Terminated Four Rings
    Aug 16 2007
    Buffalo NY
    1psi wtf?
    Ok guys need some help with this one..
    Car runs great/smooth/etc but felt balls slow so i check out my boost gauge and brake boosting in 3rd im lucky to hit 1psi! Usually i can hit 7-8!
    My car is NOT chipped just neuspeed exhaust, and a modded air bax, this just started today and NO it doesnt sound like a drill
    I searched "No Boost" on here and came up with
    -Clogged cat
    -Boost leak
    -Bad wastegate actuator
    I do have a CEL on but thats been on for a good 2 months now
    I dont have a vag com but i can get one on wednesday
    ANY OTHER IDEAS?
    May 16 2008
    WA
    Re: 1psi wtf?
    I would suggest you make a boost leak tester, sounds like that pressure is going somewhere other than the motor. Also at idle what is your boost gauge showing for vacuum?
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    Re: 1psi wtf?
    big boost leak? bad n75?
    TEAM|AXION
    Aug 16 2007
    Buffalo NY
    Re: 1psi wtf?
    idle is same as always vacuum at 23ish
    Sep 06 2007
    Bricktown, NJ
    Re: 1psi wtf?
    I had the same problem - turned out to be the crankcase breather hose - it's a cheap-o part that corroded the first time the car was chipped and it pushed it over the edge - i slowly lost pressure then it was down to 1 psi, almost as if the computer put it at that point. I fixed it and it took a few miles to work but then it spooled and all was right with the world :) just my .02
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: 1psi wtf?
    Check intercooler hoses, although that would make your car idle like shit
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Aug 16 2007
    Buffalo NY
    Re: 1psi wtf?
    a guy on another site just posted this
    "Coil pack in turn thru on limp mode"
    I have 4 extra coil packs i can try, but if this was the case and i had bad spark somewhere wouldnt it idle like poop
    Aug 16 2007
    Buffalo NY
    Re: 1psi wtf?
    Quote Originally Posted by cculos View Post
    Whats that look like? How much $$$? Did you have a cel on?
    Dec 05 2007
    Re: 1psi wtf?
    You should really get your car scanned at Autozone. VAG com is better because it will also pull intermittent codes. But since you have a solid CEL, an Autozone OBD II scanner will suffice. Then go to Ross-Tech to further analyse the cause of your issue. As for a boost leak, it seems you are boosting just fine to me. But boost leak tests are always helpfull.
    http://wiki.ross-tech.com/index.php/...ry:Fault_Codes
    Aug 16 2007
    Buffalo NY
    Re: 1psi wtf?
    k just got back with 2 codes...
    (1) coolent temp sensor input high
    (2) #4 cyl misfire
    So i bought a green top temp sensor $6.99 and i have 4 left over coils from my old 99.5
    Is the cyl closest to the radiator #4? And where is the coolent temp sensor?
    Senior Member Three Rings b5a4gt28's Avatar
    Oct 15 2007
    97 B5 BAT A4 2.0 HTA30R, 01 STG 3 S4, 04 B6 A4
    Telford Pa
    Re: 1psi wtf?
    #4 is the last cylinder on the engine. Its closest to the battery. Coolant temp sensor I believe is located under the coolant expansion tank.
    Aug 16 2007
    Buffalo NY
    Re: 1psi wtf?
    lol damnit
    Dec 05 2007
    Re: 1psi wtf?
    The coolant temp sensor is located somewhere behind the engine head. The sensor on the tank is different. http://www.audizine.com/forum/showth...ensor+location. And a bad coolant sensor can throw you into limp mode.
    Veteran Member Four Rings thenofjboy's Avatar
    Oct 08 2007
    08 S-line QMT6 , B5 KO4 & my german sheppard
    Jersey City
    Re: 1psi wtf?
    Quote Originally Posted by slopoke View Post
    i pressurized my system and found my breather hose was destroyed!! when i got my hand around it, it literally crunched in my hand. check out ECStuning:
    http://www.ecstuning.com/stage/edpd/...WD&engine=1.8T
    i got the whole kit - ECS/OEM Crankcase Breather Hose Kit ES#5942
    This is for an AEB but the pics are KEY
    http://www.passatworld.com/forums/sh...+breather+hose
    Sean
    The New
    B7---GIAC--BBS--DDM--JHM+S4Exhaust--StaSIS SS--034--AudiUP--USP--RedEBC--IE--DrakesVC#12--B7S4 Brakes--StopTech--GFB DV+--
    The Old
    B5---GIAC-K04--RACETEC--APR--DEPO--AUTOTECH--VMR--FORGE--034--H&R--BILSTEIN--FUJITA
    Aug 16 2007
    Buffalo NY
    Re: 1psi wtf?
    k just got the vag-com off the car, i also have a code for intermediate n75 failure so i will start from there
    Jan 19 2008
    Re: 1psi wtf?
    I'm curious as to what it shows in block 111 for you. Could you post that here?
    Aug 16 2007
    Buffalo NY
    Re: 1psi wtf?
    sorry was at a friends house who has the vag-com...
    Can i unplug the n75 and run it to make sure its not the wastegate actuator???
    Oct 08 2007
    Jersey City
    Re: 1psi wtf?
    what is block 111 for?
    Sean
    The New
    The Old
    Oct 08 2007
    Jersey City
    Re: 1psi wtf?
    you can unplug the hose from the N75 to the WG and see if you boost Significantly better, if so its your N75. This is what i read.....
    Do not drive that far at all, just go around the block.
    Sean
    The New
    The Old
    Jan 19 2008
    Re: 1psi wtf?
    Quote Originally Posted by thenofjboy View Post
    It's the N75 valve adjustment values like 032 is the fuel adjustment values.
