Mike,
I'm running the factory MAF housing.
I've already switched out a brand new MAF 1.5 years ago.
But MAFs going bad seem to be a common problem, but I didn't know it would be this soon.
I originally thought the unusually high CFs might have been due to my Intercooler (E-Code intercooler) because at that gear and RPM my car isn't really moving. But I think you're onto something.
Low MAF reading it is. I'm gonna have to switch it out for a new one.
Will my REVO tuning run with a 3" maf Housing?
It is odd though, that's why I decided to take out all boost and run wastegate pressure (which I thought was pretty low too). 9-10 PSI for wastegate pressure??
Another thing that came to mind, the software may be overworking the MAF because B:9 is supposed to be the manual setting for programming to figure out how much boost I'm running with an MBC. The MAP sensor and MAF may be working overtime because of this.
I haven't run my N75 since I got this 71R setup 3 years ago.
Essentially, I'm not making any more useable power over Stg 1 programming under 4500-5000 rpms at this point.
Anything else I should be looking at?
Thanks
Originally Posted by
mike-2ptzero
Odd that you are getting such a high CF reading at low rpms even on the boost 0 timing 2.
BTW what size maf housing are you running, because it seems your maf reading at idle might be a bit low(2.4) on run 2. Low readings can cause the ecu to run way more timing then it should and this could be the cause of your high CF readings. Your load readings are very low too, you should be seeing 191 if you are running a stock maf using.
