Results 1 to 3 of 3
    Active Member Two Rings InfiniIV's Avatar
    Nov 17 2008
    2006 Imola Yellow S4
    Prince George, BC
    Anyone running Raderwerks RS4 Reps?
    I had recently got a set of Raderwerks b5 rs4 reps and a set of OEM centercaps to go with them. When the caps came I tried to fit them and I can't get them to sit flush, in fact about the closest they come is about 1/4 inch above the face of the wheel. Upon closer inspection it looks like there are some small tabs at the center of the cap that stick up higher than anything else and as far as I can tell are totally useless. If these were cut I imagine the caps would fit fine but I would like to know some other peoples experiences before I resort to cutting them.
    I've been searching for a couple days now and I haven't found any record of this problem from anyone else. I'm just wondering if there is anyone else out there that has these wheels and has OEM caps that fit without any modification?
    Veteran Member Three Rings JaVa's Avatar
    Jan 07 2007
    01 A4 2.8, 85 Yota, Isuzu
    Re: Anyone running Raderwerks RS4 Reps?
    i believe there is a little nub on the wheel that needs to line up with a little cut out on the center cap. thats on my celebrations tho. hope it helps.
    NWQuattro - NorthWest Audi Group
    ----01 A4 2.8 QS Tip |GIAC|Zapco|Alpine|Dension|Tint|
    Nov 17 2008
    Prince George, BC
    Definately worth a check, thanks for the input.
