Results 1 to 6 of 6
    Junior Member Two Rings Racemagicr1's Avatar
    Feb 18 2008
    Tampa
    Need Urgent Help
    Hey so i took out my test pipe and now my car is throwing a lean code and misfiring constantly and dieing at idle can anyone help. before i took the test pipe out i had an o2 code because of the test pipe i figured but i never bothered because it was running fine now i don't knw wht to do my mechanic is clueless about wht to do on this.
    2004 Audi A4 USP 1.8T
    Senior Member Three Rings B00sted20VUSP's Avatar
    Nov 11 2008
    Junk
    Chicago, IL
    Re: Need Urgent Help
    did you install the cat back on? Make sure u didnt damage an o2 when re-installing, Check that all hoses are connected, unplug the MAF and try starting, what are your fuel trims....if you have access to them? Or at last try a Capacitive discharge.....unhook the battery cables and touch them for 20 sec. Hope this helps
    /S4 25 Quattro #139 | JHM 93 Oct Tune | Fast Intentions Non-Res Exhaust | Trexturk Downpipes | VMR Staggered Gunmetal 710's | RS4 Grille | RS4 Pedals
    Veteran Member Four Rings maclem8223's Avatar
    Oct 16 2006
    04' A4 USP 1.8T QM
    RSM, California
    Yeah, unplug the maf and see what happens, damged 02 sensor could be a problem. And I'm pretty sure (if you can check it) block 032 is fuel trim...someone correct me if I'm wrong.
    ~Matt~
    BetaAlphaTauMemeber #45
    USPMemeber #1001
    04' 1.8T Q6M 2871R Revo Tuned
    Feb 18 2008
    Tampa
    a damaged o2 can really cause tht much problems? which o2 is damaged the front of rear would it be possible to determine for sure before i get a new one some how? thanks
    Oct 16 2006
    04' A4 USP 1.8T QM
    RSM, California
    I just found this out earlier myself but run block 031 and see what the air fuel is. If it is greater than 1.00 something like 1.8... bad sensor. Thanks Greg I'll be trying that Wednesday.
    ~Matt~
    USPMemeber #1001
    Feb 18 2008
    Tampa
    hey so i disconnected the maf sensor and the car started and idle fine and drove fine so what could be the problem did that sensor go bad or is it the front O2 sensor on the cat that is causing my idle problem?
